DSS14U
DSS14U
    SMCDIODESOLUTIONS(桑德斯)
    SMF(SOD-123FL)
    肖特基二极管 40V 500mV@1A
DSS14U 数据手册
DSS12U THRU DSS125U Technical Data Data Sheet N1873, Rev. A DSS12U THRU DSS125U SINGLE PHASE 1.0AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Metal silicon junction, majority carrier conduction Low power loss, high efficiency High temperature soldering guaranteed: 260/10°C seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request        SOD-123FL Circuit Diagram Mechanical Data     Case: SOD-123FL, molded plastic Terminals: Plated leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band dentes cathode end Mounting Position: Any Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol DSS 12U DSS 13U DSS 14U DSS 15U DSS 16U DSS 18U Code D12U D13U D14U D15U D16U D18U DSS 110U DSS 115U DSS 120U DSS 125U D110U D115U D120U D125U Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM 20 30 40 50 60 80 100 150 200 250 V VRWM 20 30 40 50 60 80 100 150 200 250 V VDC 20 30 40 50 60 80 100 150 200 250 V RMS Reverse Voltage VRMS 14 21 28 35 42 56 70 105 140 175 V Average Rectified Output Current at TL=90℃ IF(AV) 1.0 A IFSM 40 A I2t Rating for Fusing (t < 8.3ms) I2 t 6.640 A2 s Forward Voltage per element @IF=1.0A VF Peak Reverse Current TA=25 ℃ at rated DC blocking voltage TA=100 ℃ IR Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on Rated load(JEDEC Method) Typical Junction Capacitance (Note 1) Junction and Storage Temperature Range CJ TJ, TSTG 0.50 0.67 0.80 0.90 0.1 0.05 10 5 110 80 -55 to +150 Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  0.92 V mA pF °C DSS12U THRU DSS125U Technical Data Data Sheet N1873, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DSS12U THRU DSS125U Technical Data Data Sheet N1873, Rev. A Mechanical Dimensions SOD-123FL(Inches/Millimeters) Ordering Information Device DSS12U THRU DSS125U Marking Diagram Package Shipping SOD-123FL (Pb-Free) 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. D12U = Marking Code Carrier Tape Specification SOD-123FL SYMBOL A B C d E F P P0 P1 W Millimeters Min. Max. 1.95 3.85 1.35 1.50 1.65 3.40 3.90 3.90 1.90 7.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  2.15 4.05 1.55 1.60 1.85 3.60 4.10 4.10 2.10 8.30 DSS12U THRU DSS125U Technical Data Data Sheet N1873, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
DSS14U 价格&库存
很抱歉,暂时无法提供与“DSS14U”相匹配的价格&库存,您可以联系我们找货
