208CMQ060
208CMQ060
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
208CMQ060 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1191, Rev. B 208CMQ060 Green Products 208CMQ060 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 150℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 208CMQ060, 1 row SS YYWWL, 2 row 208CMQ060 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 208CMQ060 Technical Data Data Sheet N1191, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Max. Average Forward IF(AV) Condition 50% duty cycle @TC =90°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 3840 A Condition @ 100A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 25 °C @ 100A, Pulse, TJ = 125 °C @ 200A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.68 0.83 0.59 0.75 Units V 1.1 mA 300 mA 6000 pF 7.0 nH 10,000 1000 V/μs V Condition - Specification -55 to +150 -55 to +150 Units °C °C 100 200 Max. 60 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current at DC condition Max. Reverse Current Max. Junction Capacitance Typical Series Inductance (per leg) Max. Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS V Pulse Width < 300µs, Duty Cycle
208CMQ060
物料型号: 208CMQ060 器件简介: 肖特基整流器,用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接。
引脚分配: 阳极1连接到端子1,阳极2连接到端子3,共用阴极连接到端子2。
后缀R表示极性反转。
PRM4(隔离型) 参数特性: 包括最大反向电压、平均正向电流、最大正向电压降、最大反向电流、最大结电容、最大电压变化率、绝缘电压等。
功能详解: 提供了详细的电气特性表和热机械规格,例如最大结温、最大存储温度、最大热阻、典型热阻等。
应用信息: 用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等。
封装信息: 封装形式为PRM4(隔离型),尺寸数据以毫米和英寸为单位提供,包括长、宽、高、安装孔径等。
208CMQ060 价格&库存
很抱歉,暂时无法提供与“208CMQ060”相匹配的价格&库存,您可以联系我们找货
208CMQ060
  • 1+567.628461+73.49091
  • 18+410.9275118+53.20282
  • 108+403.61285108+52.25580
库存:165
