163CMQ080
163CMQ080
    SMCDIODESOLUTIONS(桑德斯)
    TO-249AA
163CMQ080 数据手册
SANGDEST MICROELECTRONICS 163CMQ…SERIES Technical Data Data Sheet N1092, Rev. A Green Products 163CMQ…SERIES SCHOTTKY RECTIFIER Applications: • Switching power supply • Converters • Free-Wheeling diodes • Reverse battery protection Features: • • • • • • • • • • • 175 °C TJ operation Isolated heatsink Low profile, high current package Center tap module Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches TO-249AA MARKING, MOLDING RESIN st nd rd Marking for 163CMQ080/100, 1 row SS YYWWL, 2 row 163CMQ080/100, 3 row 1 2 3 (Pin) Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 163CMQ…SERIES Technical Data Data Sheet N1092, Rev. A Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward* Max. Peak One Cycle NonRepetitive Surge Current (peg leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol Condition VRWM 80 100 - Max. 163CMQ080 163CMQ100 Units V IF(AV) 50% duty cycle @TC = 87°C, rectangular wave form 160 A IFSM 8.3 ms, half Sine pulse 960 A EAS TJ=25℃,IAS=1A,L=30mH 15 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 1 A Symbol Condition @ 80A, Pulse, TJ = 25 °C @ 160A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 125 °C @ 160A, Pulse, TJ = 125 °C @VR = rated VR ,TJ = 25 °C @VR = rated VR ,TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.98 1.17 0.80 0.96 1.5 20 Units 1400 pF 8.0 nH 10,000 V/μs Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt V V mA mA Pulse Width < 300µs, Duty Cycle
163CMQ080
物料型号: - 163CMQ…SERIES
器件简介: - 该系列产品是肖特基整流器,应用于开关电源、转换器、自由轮二极管和反向电池保护。
引脚分配: - 163CMQ080/100型号的标记为:第一行SS YYWWL,第二行163CMQ080/100,第三行1 2 3(Pin)。YY代表制造年份,WW代表制造周代码,L代表晶圆批号。
参数特性: - 最大平均正向电流(50%占空比,Tc=87°C,矩形波形):160A - 最大峰值非重复浪涌电流(单脚):960A - 非重复雪崩能量(单脚):15mJ - 重复雪崩电流(单脚):1A - 最大正向电压降(单腿):在80A脉冲,T = 25°C时为0.98V;在160A脉冲,T = 25°C时为1.17V - 最大反向电流(单腿):在额定VR下,T = 25°C时为1.5mA - 最大结电容(单腿):在VR = 5V,Tc = 25°C,fsIG=1MHz时为1400pF - 典型串联电感(单腿):从封装体5mm处测量为8.0nH - 最大电压变化率:10,000V/us
功能详解: - 该系列产品能在175°C的TJ操作,具有隔离的散热器、低轮廓、高电流封装、中心抽头模块、低正向电压降、高纯度、耐高温环氧封装以增强机械强度和防潮性能、高频率操作、增强的护圈以提高鲁棒性和长期可靠性,并且是无铅设备。
应用信息: - 适用于开关电源、转换器、自由轮二极管和反向电池保护。
封装信息: - 封装类型为TO-249AA,采用环氧树脂UL:94V-0。
163CMQ080 价格&库存
很抱歉,暂时无法提供与“163CMQ080”相匹配的价格&库存,您可以联系我们找货
163CMQ080
    • 1+315.54360
    • 192+125.90640
    • 504+121.70520
    • 1008+119.62080
