BAT54/A/C/S
SURFACE MOUNT SCHOTTKY BARRIER DIODE
Technical Data
Data Sheet N0123, Rev. C
Green Products
BAT54/A/C/S SCHOTTKY RECTIFIER
Applications:
• Small signal switching
Features:
Negligible switching losses
Very small conduction losses
Low forward voltage drop
Surface mount device
Double diodes with different pining are available
Schottky barrier diodes encapsulated in a SOT-23 small SMD packages
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In Inches / mm
SOT-23 Package
BAT54C
Common Cathode
BAT54A
Common Anode
BAT54
Single
BAT54S
Series
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
BAT54/A/C/S
Technical Data
Green Products
Marking Diagram:
KL1/KL2/KL3/KL4
BAT54
= Part Name
BAT54A
BAT54C
BAT54S
Note: If date code is before 16221, please contact with factory about marking.
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
BAT54/A/C/S
Package
Shipping
SOT-23(Pb-Free)
3000pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
BAT54/A/C/S
Technical Data
Green Products
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Forward Current
Peak One Cycle Non-Repetitive
Surge Current
(per leg)
Power dissipation#
Symbol
VRRM
VRWM
VR
Condition
Max.
Units
30
V
IF(AV)
50% duty cycle @TC =80°C,
rectangular wave form
0.2
A
IFSM
8.3 ms, half Sine pulse
0.6
A
Ptot
Tamb = 25 °C
200
mW
Max.
0.24
0.32
0.40
0.50
1.0
Units
V
2.0
μA
100
μA
10
pF
5
ns
# for double diodes, Ptot is the total dissipation of both diodes.
Electrical Characteristics:
Characteristics
Forward Voltage Drop(per leg)*
Reverse Current(per leg)**
Symbol
VF1
IR1
IR2
Junction Capacitance
(per leg)
Reverse Recovery Time
CT
trr
Condition
@ 0.1mA, Pulse, TJ = 25 °C
@ 1mA, Pulse, TJ = 25 °C
@ 10mA, Pulse, TJ = 25 °C
@ 30mA, Pulse, TJ = 25 °C
@ 100mA, Pulse, TJ = 25 °C
@VR = rated VR, Pulse,
TJ = 25 °C
@ VR = rated VR, Pulse,
TJ = 100°C
@VR = 5.0 V, Tc=25℃
fSIG = 1MHz
IF=10mA IR = 10mA
TJ = 25 °C Irr =1 mA RL=100Ω
Pulse test:
* tp=380ms, δ
很抱歉,暂时无法提供与“BAT54STR”相匹配的价格&库存,您可以联系我们找货
