SBRF10100CT
SBRF10100CT
    SMCDIODESOLUTIONS(桑德斯)
    ITO220AB
    DIODESCHOTTKY100VITO220AB
SBRF10100CT 数据手册
SANGDEST MICROELECTRONICS SBRF10100CT Green Products Technical Data Data Sheet N0908, Rev. A SBRF10100CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150°°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm Dim A OPTION 1(CJ) Min Max 4.4 4.6 OPTION 2(HD) Min Max 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - 2.50 Q 2.5 2.9 Q1 2.5 2.9 ØR 3.5REF 2.90 2.70REF 3.50REF • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBRF10100CT Green Products Technical Data Data Sheet N0908, Rev. A OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 Q 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBRF10100CT Green Products Technical Data Data Sheet N0908, Rev. A OPTION 5 (SR) ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBRF10100CT Green Products Technical Data Data Sheet N0908, Rev. A Marking Diagram: Where XXXXX is YYWWL SBR F 10 100 CT SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) SBRF10100CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Max. Average Forward IF(AV) Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM Condition 50% duty cycle @TC = 150°C, rectangular wave form Surge applied at rated load conditions halfwave, single phase,60Hz Max. 100 Units V 10 A 120 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBRF10100CT Green Products Technical Data Data Sheet N0908, Rev. A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Repetitive peak reverse current Non-Repetitive Avalanche Energy Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IRRM EAS CT LS dv/dt Condition @ 5 A, Pulse, TC = 25 °C @ 5 A, Pulse, TC = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C tp = 2 µs square F= 1 kHz TJ = 25 °C, IAS = 5 A, L = 1mH @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.85 0.75 Units V V 1.0 mA 15.0 mA 1 A 12.5 mJ 300 pF 8.0 nH 10,000 V/µs Pulse Width < 300µs, Duty Cycle
SBRF10100CT
物料型号:SBRF10100CT 器件简介:SBRF10100CT是一款肖特基整流器,适用于开关电源、转换器、飞轮二极管、反向电池保护等应用。
引脚分配:中心抽头配置。
参数特性:150°C的工作温度,低正向电压降,高频操作,具有增强机械强度和防潮性的高纯度、高温环氧封装,以及增强的耐用性和长期可靠性的防护环。
功能详解:此肖特基整流器为无铅设备,所有SMC部件都可以追溯到晶圆批次,可以根据要求提供额外测试。
应用信息:主要应用于开关电源、转换器、飞轮二极管、反向电池保护等。
封装信息:提供ITO-220AB封装,50pcs/管。
以上信息摘自SBRF10100CT的技术数据手册。
SBRF10100CT 价格&库存
很抱歉,暂时无法提供与“SBRF10100CT”相匹配的价格&库存,您可以联系我们找货
