10CTQ150
10CTQ150S
Technical Data
Data Sheet N1308, Rev. -
Green Products
10CTQ150/10CTQ150S SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
175°C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In Inches / mm
Symbol
A
A1
A2
b
b1
c
D
D1
E
e
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in
millimeters
Min
Typical
Max
4.42
4.57
4.72
1.17
1.27
1.37
2.59
2.69
2.89
0.71
0.81
0.96
1.27
0.36
0.38
0.61
14.94
15.24
15.54
8.85
9.00
9.15
10.01
10.16
10.31
2.54
5.06
6.04
6.24
6.44
12.7
13.56
13.78
3.5
3.74
3.84
4.04
2.54
2.74
2.94
7°
3°
4°
TO-220AB(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
10CTQ150
10CTQ150S
Technical Data
Green Products
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
0.10
2.69
0.81
1.27
0.38
1.27
8.70
0.61
1.37
8.85
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
4.85
0.25
2.89
0.96
15.6
2.70
1.40
2.20
8°
D2PAK (HD)
10CTQ150
10CTQ150S
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
10CTQ150
SSG
YY
WW
L
10CTQ150
= Part Name
= SSG
= Year
= Week
= Lot Number
10CTQ150S
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
D²PAK
(Pb-Free)
10CTQ150
10CTQ150S
Shipping
50pcs / tube
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Symbol
VRRM
VRWM
VR
Condition
Average Forward Current
IF(AV)
50% duty cycle @TC =155°C,
rectangular wave form
Peak One Cycle Non-Repetitive
Surge Current
(per leg)
IFSM
8.3 ms, half Sine pulse
Max.
150
5(per leg)
10(per device)
138
Units
V
A
A
10CTQ150
10CTQ150S
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg)*
Symbol
VF1
VF2
Reverse Current(per leg)*
IR1
IR2
Junction Capacitance
CT
Typical Series Inductance
LS
Max. Voltage Rate of
Change(Rated VR)
dv/dt
Condition
@ 5A, Pulse, TJ = 25 °C
@ 10A, Pulse, TJ = 25 °C
@ 5A, Pulse, TJ = 125 °C
@ 10A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Max.
0.93
1.10
0.73
0.86
0.05
Units
V
7.0
mA
200
pF
8.0
nH
10,000
V/μs
Specification
-55 to +175
-55 to +175
3.50
Units
°C
°C
°C/W
1.75
°C/W
V
mA
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“10CTQ150STR”相匹配的价格&库存,您可以联系我们找货
