SBR20150CT
SBR20150CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
SBR20150CT 数据手册
SANGDEST MICROELECTRONICS SBR20150CT Technical Data Data Sheet N0912, Rev. - Green Products SBR20150CT SCHOTTKY RECTIFIER Applications: z z z z Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: z z z z z z z z z 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In mm / Inches) and Marking: Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Min 4.42 1.17 2.59 0.71 0.36 14.94 8.85 10.01 6.04 12.7 3.74 2.54 Dimensions in millimeters Typical 4.57 1.27 2.69 0.81 1.27 0.38 15.24 9.00 10.16 2.54 5.06 6.24 13.56 3.5 3.84 2.74 7° 3° 4° Max 4.72 1.37 2.89 0.96 0.61 15.54 9.15 10.31 6.44 13.78 4.04 2.94 OPTION1 (HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR20150CT Technical Data Data Sheet N0912, Rev. - Green Products OPTION2 (CJ) TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR20150CT Technical Data Data Sheet N0912, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL SBR 20 150 CT SSG YY WW L = Device Type = Forward Current (20A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device SBR20150CT Package Shipping TO-220AB (Pb-Free) 50 pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Symbol Condition Max. Units Peak Inverse Voltage VRWM - 150 V Max. Average Forward IF(AV) 50% duty cycle @TC =133°C, 10(Per leg) rectangular wave form 20(Per device) 8.3 ms, half Sine pulse 150 A Max. Peak One Cycle Non-Repetitive Surge Current IFSM A (per leg) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR20150CT Technical Data Data Sheet N0912, Rev. - Green Products Electrical Characteristics: Characteristics Symbol Max. Units Max. Forward Voltage Drop VF1 @ 10A, Pulse, TJ = 25 °C 0.95 V (per leg)* VF2 @ 10A, Pulse, TJ = 125 °C 0.85 V 1.0 mA 6 mA 1 A 400 pF - 10,000 V/μs Symbol Condition Specification Units Max. Junction Temperature TJ - -55 to +150 °C Max. Storage Temperature Tstg - -55 to +150 °C 3.5 °C/W 2.0 g Max. Reverse Current at DC condition (per leg) IR1 IR2 Repetitive peak reverse current Max. Junction Capacitance (per leg) Max. Voltage Rate of Change * Condition IRRM CT @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C tp = 2 μs square F= 1 kHz @VR = 5V, TC = 25 °C fSIG = 1MHz dv/dt Pulse Width < 300µs, Duty Cycle
SBR20150CT
物料型号:TI公司的LM77AKT 器件简介:LM77AKT是TI公司生产的温度传感器,具有数字I2C接口,能够测量温度范围为-40℃至+85℃。
引脚分配:LM77AKT有8个引脚,包括VDD、GND、SCL、SDA、NC、ALERT、NC、NC。
参数特性:LM77AKT的供电电压范围是2.5V至5.5V,温度测量精度为0.5℃,分辨率为0.0625℃。
功能详解:LM77AKT提供温度实时监测功能,支持中断功能,可设置温度报警点。
应用信息:LM77AKT适用于电脑、服务器、通信设备等需要温度监控的场合。
封装信息:LM77AKT采用8脚SOIC封装。
SBR20150CT 价格&库存
很抱歉,暂时无法提供与“SBR20150CT”相匹配的价格&库存,您可以联系我们找货
