MBRF2045CTU
Technical Data
Data Sheet N1070, Rev. A
Green Products
MBRF2045CTU SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
125°C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for
enhanced mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
OUTLINE DRAWING
Mechanical Dimensions (In mm):
SYMBOL
A
A1
A2
A3
b
b1
b2
b3
b4
c
D
E
e
e1
H1
L
L1
L2
L3
ΦP1(上口)
ΦP2(下口)
Q
Θ1
Θ2
Θ3
Θ4
Θ5
MIN.
4.30
1.10
2.80
2.50
0.50
1.10
1.50
1.20
1.60
0.55
14.80
9.96
6.50
12.70
1.60
0.80
0.60
3.30
2.99
2.50
TYP.
4.50
1.30
3.00
2.70
0.60
1.20
1.60
1.30
1.70
0.60
15.00
10.16
2.55
5.10
6.70
13.20
1.80
1.00
0.80
3.50
3.19
2.70
5°
4°
10°
5°
5°
ITO-220AB(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
MAX.
4.70
1.50
3.20
2.90
0.75
1.35
1.75
1.45
1.85
0.75
15.20
10.36
6.90
13.70
2.00
1.20
1.00
3.70
3.39
2.90
MBRF2045CTU
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
F
CTU
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (20A)
= Reverse Voltage (45V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
ITO-220AB
(Pb-Free)
MBRF2045CTU
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current (per device)
Peak One Cycle Non-Repetitive
Surge Current
(per leg)
Symbol
VRRM
VRWM
VR
Condition
IF (AV)
50% duty cycle @TC =80°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
Max.
45
Units
V
A
200
A
MBRF2045CTU
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current at DC
condition (per leg) *
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
RSM Isolation Voltage
(t = 1.0 second, R. H. < =30%,
TA = 25 °C)
Symbol
VF1
IR1
IR2
CT
LS
VISO
Condition
@ 10A, Pulse, TJ = 25 °C
Typ.
0.43
Max.
0.50
Units
V
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Clip mounting, the epoxy body
away from the heatsink edge by
more than 0.110" along the lead
direction.
Clip mounting, the epoxy body is
inside the heatsink.
Screw mounting, the epoxy
body is inside the heatsink.
0.002
1
mA
18
200
mA
560
750
pF
8.0
nH
4500
V
3500
1500
Condition
DC operation
Specification
-55 to +125
-55 to +125
5.0
Units
°C
°C
°C/W
2
g
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBRF2045CTU”相匹配的价格&库存,您可以联系我们找货
