MBR2050CT-1
MBR2050CT-1
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    DIODE SCHOTTKY 50V TO262
MBR2050CT-1 数据手册
MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBR2050CT MBR2060CT TO-220AB Case styles MBRB2050CT D2PAK MBR2050CT-1 MBR2060CT-1 TO-262 Mechanical Dimensions: In Inches / mm TO-220AB(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° D2PAK(HD) TO-262 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Marking Diagram: Where XX is Reverse Voltage Where XXXXX is YYWWL MBR B 20 XX CT/CT-1 SSG YY WW L MBR20XXCT = Device Type = Package type = Forward Current (20A) = Reverse Voltage (50/60V) = Configuration = SSG = Year = Week = Lot Number MBRB2050CT Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR20XXCT MBR20XXCT-1 Package TO-220AB (Pb-Free) D²PAK (Pb-Free) MBRB2050CT Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Output Current(Per device) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR Condition - 50 60 Max. MBR2050CT MBR2060CT Units V Io 50% duty cycle @TC =80°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current (per leg)* IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Max. Voltage Rate of Change * CT LS dv/dt Condition @ 10A, Pulse, TJ = 25 ℃ @ 20A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 125 ℃ @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 ℃ @VR = rated VR TJ = 125 ℃ @VR = 5V, TC = 25 ℃ fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.66 0.85 0.61 0.75 Max. 0.80 0.95 0.70 0.85 Units 0.075 1.0 mA 4 150 mA 260 400 pF 8.0 - nH - 10,000 V/μs V V Pulse Width < 300µs, Duty Cycle
MBR2050CT-1
物料型号: - MBR2050CT - MBR2060CT - MBRB2050CT - MBR2050CT-1 - MBR2060CT-1
器件简介: 这些是肖特基整流器,应用于开关电源、转换器、自由轮流通二极管和反向电池保护。特点包括150℃ TJ操作、中心抽头配置、低正向电压降、高纯度、高温环氧封装以增强机械强度和防潮性、高频操作、防护环以增强鲁棒性和长期可靠性。这是一个无铅设备,所有SMC部件都可以追溯到晶圆批次。
引脚分配: - MBR2050CT MBR2060CT:TO-220AB封装 - MBRB2050CT:D2PAK封装 - MBR2050CT-1 MBR2060CT-1:TO-262封装
参数特性: - 峰值重复反向电压(VRRM):MBR2050CT为50V,MBR2060CT为60V - 工作峰值反向电压(VRWM VR):MBR2060CT为60V - 平均整流输出电流(每设备):在Tc=80°C、50%占空比、矩形波形条件下为20A
功能详解: 这些肖特基整流器适用于需要高效率和高可靠性的应用场合,如开关电源和电池保护。它们的低正向电压降有助于减少功率损耗,而高频率操作能力使它们适合用于高频电路。
应用信息: - 开关电源 - 转换器 - 自由轮流通二极管 - 反向电池保护
封装信息: - TO-220AB - D2PAK - TO-262
MBR2050CT-1 价格&库存
很抱歉,暂时无法提供与“MBR2050CT-1”相匹配的价格&库存,您可以联系我们找货
