30CTQ050
30CTQ050
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODE ARRAY SCHOTTKY 50V TO220AB
30CTQ050 数据手册
30CTQ050/60 30CTQ050/60S 30CTQ050/60-1 Technical Data Data Sheet N0683, Rev. - Green Products 30CTQ050/60/30CTQ050/60S /30CTQ050/60-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 30CTQ… TO-220AB Case styles 30CTQ…S D2PAK Mechanical Dimensions: In Inches / mm 30CTQ…-1 TO-262 TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 30CTQ050/60 30CTQ050/60S 30CTQ050/60-1 Technical Data Data Sheet N0683, Rev. - Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 D2PAK Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° TO-262 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 30CTQ050/60 30CTQ050/60S 30CTQ050/60-1 Technical Data Data Sheet N0683, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL 30CTQ050 SSG YY WW L 30CTQ050 =Part Name = SSG = Year = Week = Lot Number 30CTQ050S Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) D²PAK (Pb-Free) 30CTQ… 30CTQ…S Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR IF(AV) IFSM Condition - Max. 50(30CTQ050/S) 60(30CTQ060/S) Units V 50% duty cycle @TC = 105°C, rectangular wave form 30 A 8.3 ms, half Sine pulse 310 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 30CTQ050/60 30CTQ050/60S 30CTQ050/60-1 Technical Data Data Sheet N0683, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current(per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125°C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.62 0.56 Units V V 1.0 mA 45 mA 720 pF 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C 3.25 °C/W Pulse Width < 300µs, Duty Cycle
30CTQ050 价格&库存
很抱歉,暂时无法提供与“30CTQ050”相匹配的价格&库存,您可以联系我们找货
