30CTQ050/60
30CTQ050/60S
30CTQ050/60-1
Technical Data
Data Sheet N0683, Rev. -
Green Products
30CTQ050/60/30CTQ050/60S /30CTQ050/60-1
SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150°C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
30CTQ…
TO-220AB
Case styles
30CTQ…S
D2PAK
Mechanical Dimensions: In Inches / mm
30CTQ…-1
TO-262
TO-220AB
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
30CTQ050/60
30CTQ050/60S
30CTQ050/60-1
Technical Data
Green Products
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
D2PAK
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
0.10
2.69
0.81
1.27
0.38
1.27
8.70
0.61
1.37
8.85
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
4.85
0.25
2.89
0.96
15.6
2.70
1.40
2.20
8°
TO-262
30CTQ050/60
30CTQ050/60S
30CTQ050/60-1
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
30CTQ050
SSG
YY
WW
L
30CTQ050
=Part Name
= SSG
= Year
= Week
= Lot Number
30CTQ050S
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
D²PAK
(Pb-Free)
30CTQ…
30CTQ…S
Shipping
50pcs / tube
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Forward Current
Peak One Cycle Non-Repetitive
Surge Current (per leg)
Symbol
VRRM
VRWM
VR
IF(AV)
IFSM
Condition
Max.
50(30CTQ050/S)
60(30CTQ060/S)
Units
V
50% duty cycle @TC = 105°C,
rectangular wave form
30
A
8.3 ms, half Sine pulse
310
A
30CTQ050/60
30CTQ050/60S
30CTQ050/60-1
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current(per leg) *
Symbol
VF1
VF2
IR1
IR2
Junction Capacitance
(per leg)
Voltage Rate of Change
CT
dv/dt
Condition
@ 15A, Pulse, TJ = 25 °C
@ 15A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125°C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Max.
0.62
0.56
Units
V
V
1.0
mA
45
mA
720
pF
10,000
V/μs
Specification
-55 to +150
-55 to +150
Units
°C
°C
3.25
°C/W
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“30CTQ060”相匹配的价格&库存,您可以联系我们找货
