25CTQ040STR
25CTQ040STR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    DIODESCHOTTKY40V15AD2PAK
25CTQ040STR 数据手册
25CTQ… 25CTQ…S 25CTQ…-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0024, Rev. - Green Products 25CTQ…/25CTQ…S/25CTQ…-1 SCHOTTKY RECTIFIER Applications: • Switching power supply • Free-Wheeling diodes • Reverse battery protection • Converters Features: • • • • • • • • • • 150 ℃ TJ operation Center tap configuration High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 25CTQ… TO-220AB Case styles 25CTQ…S D2PAK 25CTQ…-1 TO-262 Mechanical Dimensions: In Inches / mm TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • 25CTQ… 25CTQ…S 25CTQ…-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0024, Rev. - Green Products Symbol D2PAK A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° TO-262 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • 25CTQ… 25CTQ…S 25CTQ…-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0024, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL 25CTQ045 = Part Name SSG = SSG YY = Year WW = Week L = Lot Number 25CTQ045 25CTQ045S Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device 25CTQ045 25CTQ045S Package TO-220AB (Pb-Free) D²PAK (Pb-Free) Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • 25CTQ… 25CTQ…S 25CTQ…-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0024, Rev. - Green Products Maximum Ratings: Characteristics Symbol Condition Peak Inverse Voltage VRWM - Max. Average Forward IF(AV) 50% duty cycle @TC =102°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse Max. 35(25CTQ035) 40(25CTQ040) 45(25CTQ045) Units 30 A 300 A Max. 0.56 0.71 0.50 0.64 1.0 Units V 70 mA 900 pF 8.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 3.25 Units °C °C °C/W V Electrical Characteristics: Characteristics Symbol VF1 Max. Forward Voltage Drop* VF2 Max. Reverse Current at DC condition Max. Reverse Current IR1 Max. Junction Capacitance CT Typical Series Inductance LS Max. Voltage Rate of Change(Rated VR) * IR2 dv/dt Condition @ 15A, Pulse, TJ = 25 °C @ 30A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @ 30A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - V mA Pulse Width < 300µs, Duty Cycle
25CTQ040STR
物料型号: - 25CTQ…/25CTQ…S/25CTQ…-1
器件简介: - 该器件是一款肖特基整流器,适用于开关电源、自由轮流通路二极管、反向电池保护和转换器等应用。
引脚分配: - 25CTQ…:TO-220AB封装 - 25CTQ…S:D2PAK封装 - 25CTQ…-1:TO-262封装
参数特性: - 最高工作结温(TJ):150℃ - 中心抽头配置 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 低正向电压降 - 高频运行 - 保护环增强了坚固性和长期可靠性 - 符合RoHS指令的绿色产品 - 无铅设备
功能详解: - 该肖特基整流器具有低正向电压降和高频率运行的特点,适用于需要高效率和高可靠性的场合。
应用信息: - 开关电源 - 自由轮流通路二极管 - 反向电池保护 - 转换器
封装信息: - TO-220AB、D2PAK、TO-262 - 每种封装的具体尺寸和机械参数在文档中有详细描述。
25CTQ040STR 价格&库存
很抱歉,暂时无法提供与“25CTQ040STR”相匹配的价格&库存,您可以联系我们找货
