MBR4080/90/100CT
Technical Data
Data Sheet N0771, Rev. A
Green Products
MBR4080/90/100CT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm
Symbol
A
A1
A2
b
b1
c
D
D1
E
e
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in
millimeters
Min
Typical
Max
4.42
4.57
4.72
1.17
1.27
1.37
2.59
2.69
2.89
0.71
0.81
0.96
1.27
0.36
0.38
0.61
14.94
15.24
15.54
8.85
9.00
9.15
10.01
10.16
10.31
2.54
5.06
6.04
6.24
6.44
12.7
13.56
13.78
3.5
3.74
3.84
4.04
2.54
2.74
2.94
7°
3°
4°
OPTION 1(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
MBR4080/90/100CT
Technical Data
Green Products
OPTION 2(SR)
TO-220AB
MBR4080/90/100CT
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
40
100
CT
SSG
YY
WW
L
= Device Type
= Forward Current (40A)
= Reverse Voltage (100V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
MBR40100CT
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Symbol
VRWM
Condition
80
90
100
Average Forward
Current(per device)
Peak One Cycle NonRepetitive Surge Current
(per leg)
IF(AV)
50% duty cycle @TC = 110°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
Max.
MBR4080CT
MBR4090CT
MBR40100CT
40
250
Units
V
A
A
MBR4080/90/100CT
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop(per
leg) *
Reverse Current (per leg) *
Symbol
VF1
VF2
IR1
IR2
Junction Capacitance
(per leg)
Voltage Rate of Change
CT
dv/dt
Condition
@ 20 A, Pulse, TJ = 25 °C
@ 20 A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Max.
0.88
0.74
1.0
Units
V
V
mA
mA
400
pF
10,000
V/μs
Specification
-55 to +150
-55 to +150
2.0
Units
°C
°C
2
g
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR4090CT”相匹配的价格&库存,您可以联系我们找货
