MBRF4080CTL
MBRF4080CTL
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODESCHOTTKY80VITO220AB
MBRF4080CTL 数据手册
SANGDEST MICROELECTRONICS MBRF4080CTL Green Products Technical Data Data Sheet N1120, Rev. A MBRF4080CTL SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150℃ ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB(HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF4080CTL Green Products Technical Data Data Sheet N1120, Rev. A Marking Diagram: Where XXXXX is YYWWL MBR F 40 80 CTL SSG YY WW L = Device Type = Package Type = Forward Current (40A) = Reverse Voltage (80V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF4080CTL Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Rectified Output Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Io IFSM Condition Max. 80 Units V 50Hz Full Sine Wave Resistive Load @TC = 80 °C 40 A 50Hz Full Sine Wave 400 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF4080CTL Green Products Technical Data Data Sheet N1120, Rev. A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Max. Voltage Rate of Change * Symbol VF1 IR1 CT dv/dt Condition @ 20A, Pulse, TJ = 25 °C Max. 0.75 Units V 1.0 mA @VR = rated VR Pulse TJ = 25 °C @VR = 4V, TC = 25 °C fSIG = 1MHz - 900 pF 10,000 V/µs Condition DC operation Specification -55 to +150 -55 to +150 2.3 Units °C °C 0.50 °C/W 2 g Pulse Width < 300µs, Duty Cycle
MBRF4080CTL
物料型号:MBRF4080CTL
器件简介:这是一种肖特基整流器,适用于开关电源、转换器、自由轮二极管、反极性电池保护等应用。
引脚分配:文档中未明确提供引脚分配图或说明,但通常肖特基二极管会有阳极和阴极两个引脚。
参数特性: - 工作结温范围:-55°C 至 +150°C - 存储温度范围:-55°C 至 +150°C - 最大热阻(结到外壳):2.3°C/W - 典型热阻(外壳到散热器):0.50°C/W(仅适用于TO-220封装)
功能详解: - 肖特基二极管具有低正向电压降、高频率操作能力、增强的机械强度和防潮性,以及长期可靠性。
应用信息: - 适用于需要高效率和高可靠性的电源转换场景。
封装信息: - 封装类型:ITO-220AB(无铅) - 机械尺寸和重量在文档中有详细说明。
MBRF4080CTL 价格&库存
很抱歉,暂时无法提供与“MBRF4080CTL”相匹配的价格&库存,您可以联系我们找货
