MBRF40150CTL
MBRF40150CTL
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODESCHOTTKY150VITO220AB
MBRF40150CTL 数据手册
SANGDEST MICROELECTRONICS MBRF40150CTL Green Products Technical Data Data Sheet N0860, Rev. A MBRF40150CTL SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150°°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm / Inches OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min A 4.4 4.6 Max 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 0.50 0.75 D C 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 0.60TYP 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 13.2 12.8 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF 2.70REF 3.50REF • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF40150CTL Green Products Technical Data Data Sheet N0860, Rev. A OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 Q 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF40150CTL Green Products Technical Data Data Sheet N0860, Rev. A OPTION 5(SR) ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF40150CTL Green Products Technical Data Data Sheet N0860, Rev. A Marking Diagram: Where XXXXX is YYWWL MBR F 40 150 CTL SSG YY WW L = Device Type = Package type = Forward Current (40A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF40150CTL Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =133°C, rectangular wave form 8.3 ms, half Sine pulse Max. 150 20(per leg) 40(Per device) 432 Units V A A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF40150CTL Green Products Technical Data Data Sheet N0860, Rev. A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg)* Max. Reverse Current at DC condition (per leg) Max. Reverse Current (per leg)* Non-Repetitive Avalanche Energy Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * Symbol VF1 VF2 IR1 IR2 EAS CT LS dv/dt VISO Condition @ 20A, Pulse, TJ = 25 °C @ 20 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C TJ = 25 °C, IAS = 2 A, L = 1mH @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.95 0.80 1.0 Units V V mA 15.0 mA 2 mJ 900 pF 8.0 nH 10,000 4500 V/µs V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF40150CTL
物料型号:MBRF40150CTL
器件简介: MBRF40150CTL 是一款肖特基整流器,适用于开关电源、转换器、自由轮流通路二极管和反向电池保护等应用。
特点包括150°C TJ操作、中心抽头配置、低正向电压降、高纯度、高温度环氧封装以增强机械强度和防潮性能、高频率操作、加固环以增强鲁棒性和长期可靠性。
此外,该设备是无铅的,所有SMC部件都可以追溯到晶圆批次。
引脚分配: MBRF40150CTL 有3个引脚,分别为中心抽头、阴极和阳极。
参数特性: - 峰值反向电压(VRWM):150V - 最大正向电压降(VF1):在20A脉冲、25°C时为0.95V - 最大反向电流(IR1):在额定VR、25°C时为1.0mA - 非重复雪崩能量(EAS):在TJ=25°C、IAs=2A、L=1mH时为2mJ - 最大结电容(CT):在VR=5V、Tc=25°C、fsIG=1MHz时为900pF - 典型串联电感(Ls):从封装体引脚到引脚测量为5mm时为8.0nH - 最大电压变化率(dv/dt):10,000V/us - RSM隔离电压:根据安装方式,分别为4500V、3500V或1500V
功能详解: MBRF40150CTL 设计用于高效率和高可靠性的电源转换应用。
其肖特基技术提供了低正向电压降,有助于提高电源系统的能效。
中心抽头配置允许器件在全波整流应用中使用,而加固环设计则提高了器件的鲁棒性,使其能够在恶劣的电气和环境条件下稳定运行。
应用信息: MBRF40150CTL 适用于需要高效率和高可靠性的电源转换应用,如开关电源、转换器、自由轮流通路二极管和反向电池保护。
封装信息: MBRF40150CTL 采用 ITO-220AB 封装,这是一种表面贴装封装,适用于自动装配过程。
封装材料为环氧树脂,符合 UL94V-0 阻燃等级。
封装的尺寸和重量信息在文档中有详细描述。
MBRF40150CTL 价格&库存
很抱歉,暂时无法提供与“MBRF40150CTL”相匹配的价格&库存,您可以联系我们找货
