SDUR3020CT
SDUR3020CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
SDUR3020CT 数据手册
SDUR3020CT Technical Data Data Sheet N0382, Rev. A Green Products SDUR3020CT ULTRAFAST PLASTIC RECTIFIER Applications: • • • • • • • • Antiparallel diode for high frequency switching devices Anti saturation diode Snubber diode Free wheeling diode in converters and motor control circuits Rectifiers in switch mode power supplies (SMPS) Inductive heating and melting Uninterruptible power supplies (UPS) Ultrasonic cleaners and welders Features: • • • • • • • • Ultra-Fast Switching High Current Capability Low Reverse Leakage Current High Surge Current Capability Plastic Material has UL Flammability Classification 94V-O This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min Typical Max 4.42 4.57 4.72 1.17 1.27 1.37 2.59 2.69 2.89 0.71 0.81 0.96 1.27 0.36 0.38 0.61 14.94 15.24 15.54 8.85 9.00 9.15 10.01 10.16 10.31 2.54 5.06 6.04 6.24 6.44 12.7 13.56 13.78 3.5 3.74 3.84 4.04 2.54 2.74 2.94 7° 3° 4° TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SDUR3020CT Technical Data Data Sheet N0382, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL SDUR 30 20 CT SSG YY WW L = Device Type = Forward Current (30A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) SDUR3020CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition Max. Units - 200 V Average Rectified Forward Current IF (AV) Rated Vr ,@Tc=105°C 30 A Peak One Cycle Non-Repetitive Surge Current(Per device) IFSM 8.3ms, Half Sine pulse 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SDUR3020CT Technical Data Data Sheet N0382, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (Per leg)* Symbol Typ. 1.01 1.19 0.91 1.13 Max. 1.05 0.95 - Units 0.3 10 μA 51 500 uA trr Condition @ 15A, Pulse, TJ = 25°C @ 30A, Pulse, TJ = 25°C @ 15A, Pulse, TJ = 125°C @ 30A, Pulse, TJ = 125°C @VR = rated VR TJ = 25°C @VR = rated VR TJ = 125°C IF=500mA, IR=1A,and Irm=250mA 25 35 ns trr IF=1A, VR=30V, -diF/dt=200A/us 31 - ns VF1 VF2 Reverse Current(Per leg)* IR1 IR2 Reverse Recovery Time Reverse Recovery Time V V * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Case Approximate Weight Case Style Symbol TJ Tstg RθJC wt Condition DC operation - Specification -55 to +175 -55 to +175 1.6 Units °C °C °C/W 2 g TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SDUR3020CT Technical Data Data Sheet N0382, Rev. A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SDUR3020CT Technical Data Data Sheet N0382, Rev. A Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
SDUR3020CT
1. 物料型号:SDUR3020CT 2. 器件简介:这是一种用于高频开关设备的反并联二极管,也可作为消饱和二极管、滤波二极管、转换器和电机控制电路中的自由轮二极管,以及开关电源、感应加热和熔化、不间断电源、超声波清洗器和焊接机中的整流器。 3. 引脚分配:文档中提供了机械尺寸和引脚布局,例如阳极公共端、阳极等。 4. 参数特性:包括超快速开关、高电流能力、低反向漏电流、高浪涌电流能力,并且是无铅设备,具有UL94V-0的易燃性分类。 5. 功能详解:文档详细列出了最大额定值和电气特性,如峰值重复反向电压、工作峰值反向电压、直流阻断电压、平均整流前向电流、峰值单周期非重复浪涌电流等。 6. 应用信息:适用于多种应用场景,如高频开关设备、消饱和二极管、滤波二极管等。 7. 封装信息:采用TO-220AB封装,提供50pcs/管的运输方式。
SDUR3020CT 价格&库存
很抱歉,暂时无法提供与“SDUR3020CT”相匹配的价格&库存,您可以联系我们找货
