DSSK48-003BS-TUBE
DSSK48-003BS-TUBE
    IXYSCORPORATION
    TO263
    DIODE ARRAY SCHOTTKY 30V TO263
DSSK48-003BS-TUBE 数据手册
DSSK48-003BS Schottky Diode VRRM = 30 V I FAV = 2x 25 A VF = 0.35 V High Performance Schottky Diode Low Loss and Soft Recovery Common Cathode Part number DSSK48-003BS Marking on Product: DSSK48-003BS Backside: cathode 1 2/4 3 Features / Advantages: Applications: Package: TO-263 (D2Pak) ● Very low Vf ● Extremely low switching losses ● Low Irm values ● Improved thermal behaviour ● High reliability circuit operation ● Low voltage peaks for reduced protection circuits ● Low noise switching ● Rectifiers in switch mode power supplies (SMPS) ● Free wheeling diode in low voltage converters ● Industry standard outline ● RoHS compliant ● Epoxy meets UL 94V-0 Disclaimer Notice Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for, and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics. IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20190222b DSSK48-003BS Ratings Schottky Conditions Symbol VRSM Definition max. non-repetitive reverse blocking voltage TVJ = 25°C VRRM max. repetitive reverse blocking voltage TVJ = 25°C 30 V IR reverse current, drain current VF forward voltage drop I FAV average forward current VF0 threshold voltage rF slope resistance R thJC thermal resistance junction to case min. VR = 30 V TVJ = 25°C 20 mA 30 V TVJ = 100°C 60 mA TVJ = 25°C 0.44 V 0.54 V 0.35 V IF = 20 A IF = 40 A IF = 20 A IF = 40 A TVJ = 125 °C TC = 130 °C 0.48 V T VJ = 150 °C 25 A TVJ = 150 °C 0.19 V 6.8 mΩ d = 0.5 for power loss calculation only 1.2 K/W R thCH thermal resistance case to heatsink Ptot total power dissipation I FSM max. forward surge current t = 10 ms; (50 Hz), sine; VR = 0 V TVJ = 45°C CJ junction capacitance VR = TVJ = 25°C © 2019 IXYS all rights reserved max. Unit 30 V VR = rectangular IXYS reserves the right to change limits, conditions and dimensions. typ. K/W 0.25 TC = 25°C 5 V f = 1 MHz 105 300 1.77 Data according to IEC 60747and per semiconductor unless otherwise specified W A nF 20190222b DSSK48-003BS Package Ratings TO-263 (D2Pak) Symbol I RMS Definition Conditions RMS current per terminal min. TVJ virtual junction temperature T op operation temperature Tstg storage temperature -55 typ. max. 35 Unit A -55 150 °C -55 125 °C 150 °C 1.5 Weight FC 20 mounting force with clip g 60 N Product Marking XXXXXXXXX Part Number IXYS yywwZ Logo Date Code Location 123456 Lot# Ordering Standard Alternative Ordering Number DSSK48-003BS-TRL DSSK48-003BS-TUB Similar Part DSSK48-003B DSSK48-0025B Equivalent Circuits for Simulation I V0 R0 Marking on Product DSSK48-003BS DSSK48-003BS Package TO-220AB (3) TO-220AB (3) * on die level Delivery Mode Tape & Reel Tube Code No. 484326 484318 Voltage class 30 25 T VJ = 150°C Schottky V 0 max threshold voltage 0.19 V R0 max slope resistance * 3.6 mΩ IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Quantity 800 50 Data according to IEC 60747and per semiconductor unless otherwise specified 20190222b DSSK48-003BS Outlines TO-263 (D2Pak) Dim. W A A1 H D E Supplier Option D1 L1 c2 4 L L2 1 2 3 c 2x e 3x b2 10.92 (0.430) E1 W Inches min max 0.160 0.190 typ. 0.004 0.095 0.020 0.039 0.045 0.055 0.016 0.029 0.045 0.055 0.330 0.370 0.315 0.350 0.098 0.380 0.410 0.245 0.335 0,100 BSC 0.169 0.575 0.625 0.070 0.110 0.040 0.066 typ. 0.002 0.0008 All dimensions conform with and/or within JEDEC standard. 1.78 (0.07) 3.05 (0.120) 3.81 (0.150) 9.02 (0.355) mm (Inches) 2x b A A1 A2 b b2 c c2 D D1 D2 E E1 e e1 H L L1 Millimeter min max 4.06 4.83 typ. 0.10 2.41 0.51 0.99 1.14 1.40 0.40 0.74 1.14 1.40 8.38 9.40 8.00 8.89 2.5 9.65 10.41 6.22 8.50 2,54 BSC 4.28 14.61 15.88 1.78 2.79 1.02 1.68 typ. 0.040 0.02 2.54 (0.100) Recommended min. foot print 1 IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved 2/4 3 Data according to IEC 60747and per semiconductor unless otherwise specified 20190222b DSSK48-003BS Schottky 40 10000 3000 1000 T =150°C VJ 2000 30 100 IF IR TVJ = 150°C 125°C 25°C 20 [A] 10 [mA] 125°C TVJ = 25°C CT 100°C [pF] 1000 75°C 1 50°C 10 0.1 25°C 500 0.01 0.0 0.2 0.4 0.6 0 10 20 30 VR [V] VF [V] Fig. 1 Max. forward voltage drop characteristics 10 20 30 VR [V] Fig. 2 Typ. reverse current IR vs. reverse voltage VR 40 0 Fig. 3 Typ. junction capacitance CT vs. reverse voltage VR 16 d = 0.5 12 DC P(AV) IF(AV) 20 d= DC 0.5 0.33 0.25 0.17 0.08 8 [W] [A] 4 0 0 0 40 80 120 160 0 TC [°C] 10 20 30 40 IF(AV) [A] Fig. 5 Forward power loss characteristics Fig. 4 Average forward current IF(AV) vs. case temp. TC 1.2 ZthJC 0.8 [K/W] 0.4 Note: All curves are per diode 1 10 100 1000 10000 t [ms] Fig. 6 Transient thermal impedance junction to case at various duty cycles IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20190222b
DSSK48-003BS-TUBE 价格&库存
很抱歉,暂时无法提供与“DSSK48-003BS-TUBE”相匹配的价格&库存,您可以联系我们找货
