80CNQ040SM
80CNQ040SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SM
80CNQ040SM 数据手册
80CNQ SERIES Technical Data Data Sheet N1058, Rev. - Green Products 80CNQ035/80CNQ040/80CNQ045 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 80CNQ… Case Styles 80CNQ…SL 80CNQ…SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 80CNQ SERIES Technical Data Data Sheet N1058, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 80CNQ035/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 80CNQ035/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 80CNQ SERIES Technical Data Data Sheet N1058, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 80CNQ035 PRM2 Nickel plated 48pcs / box 80CNQ035S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 80CNQ035SL PRM2-SL Pure Sn plated 100pcs / box 80CNQ035SM PRM2-SM Nickel plated 48pcs / box 80CNQ035SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 80CNQ040 PRM2 Nickel plated 48pcs / box 80CNQ040S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 80CNQ040SL PRM2-SL Pure Sn plated 100pcs / box 80CNQ040SM PRM2-SM Nickel plated 48pcs / box 80CNQ040SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 80CNQ045 PRM2 Nickel plated 48pcs / box 80CNQ045S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 80CNQ045SL PRM2-SL Pure Sn plated 100pcs / box 80CNQ045SM PRM2-SM Nickel plated 48pcs / box 80CNQ045SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 80CNQ SERIES Technical Data Data Sheet N1058, Rev. - Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRRM VRWM VR Condition - Max. 35(80CNQ035) 40(80CNQ040) 45(80CNQ045) Units V IF(AV) 50% duty cycle @TC =114°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 900 A EAS TJ=25℃,IAS=8A,L=1.7mH 54 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 8 A Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.51 0.56 0.45 0.46 0.2 100 Max. 0.55 0.66 0.47 0.61 5 250 Units 2000 2600 pF 5.5 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C V V mA mA Pulse Width < 300µs, Duty Cycle
80CNQ040SM 价格&库存
很抱歉,暂时无法提供与“80CNQ040SM”相匹配的价格&库存,您可以联系我们找货
