84CNQ040
84CNQ040
    SMCDIODESOLUTIONS(桑德斯)
    PRM2
84CNQ040 数据手册
84CNQ SERIES Technical Data Data Sheet N1063, Rev. - Green Products 84CNQ035/84CNQ040/84CNQ045 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 125℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 84CNQ… Case Styles 84CNQ…SL 84CNQ…SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 84CNQ SERIES Technical Data Data Sheet N1063, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 84CNQ035/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 84CNQ035/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 84CNQ SERIES Technical Data Data Sheet N1063, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 84CNQ035 PRM2 48pcs / box 84CNQ035S PRM2 Nickel plated Pure Sn dipped (dipped height 6-8 mm) 84CNQ035SL PRM2-SL Pure Sn plated 100pcs / box 84CNQ035SM PRM2-SM Nickel plated 48pcs / box 84CNQ035SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 84CNQ040 PRM2 Nickel plated 48pcs / box 84CNQ040S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 84CNQ040SL PRM2-SL Pure Sn plated 100pcs / box 84CNQ040SM PRM2-SM Nickel plated 48pcs / box 84CNQ040SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 84CNQ045 PRM2 Nickel plated 48pcs / box 84CNQ045S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 84CNQ045SL PRM2-SL Pure Sn plated 100pcs / box 84CNQ045SM PRM2-SM Nickel plated 48pcs / box 84CNQ045SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 84CNQ SERIES Technical Data Data Sheet N1063, Rev. - Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Symbol VRRM VRWM VR Condition - Max. 35 (84CNQ035) 40 (84CNQ040) 45 (84CNQ045) Units V IF(AV) 50% duty cycle @TC =91°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 750 A EAS TJ=25℃,IAS=8A,L=1.7mH 54 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 8 A Repetitive Avalanche Current(peg leg) Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.43 0.52 0.38 0.49 1.5 600 Max. 0.49 0.62 0.44 0.60 5 800 Units 2100 2600 pF 5.5 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
84CNQ040 价格&库存
很抱歉,暂时无法提供与“84CNQ040”相匹配的价格&库存,您可以联系我们找货
84CNQ040
  • 1056+141.055241056+18.33293
