82CNQ030SM
82CNQ030SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SM
82CNQ030SM 数据手册
82CNQ030 Technical Data Data Sheet N1061, Rev. - Green Products 82CNQ030 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 82CNQ030 Case Styles 82CNQ030SL 82CNQ030SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 82CNQ030 Technical Data Data Sheet N1061, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 82CNQ030, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 82CNQ030, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 82CNQ030 Technical Data Data Sheet N1061, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 82CNQ030 PRM2 48pcs / box 82CNQ030S PRM2 Nickel plated Pure Sn dipped (dipped height 6-8 mm) 82CNQ030SL PRM2-SL Pure Sn plated 100pcs / box 82CNQ030SM PRM2-SM Nickel plated 48pcs / box 82CNQ030SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRRM VRWM VR Condition Max. Units - 30 V IF(AV) 50% duty cycle @TC =119°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 1060 A EAS TJ=25℃,IAS=8A,L=1.12mH 36 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 8 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 82CNQ030 Technical Data Data Sheet N1061, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.45 0.34 0.18 180 Max. 0.47 0.55 0.37 0.47 5 280 Units 2900 3700 pF 5.5 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
82CNQ030SM 价格&库存
很抱歉,暂时无法提供与“82CNQ030SM”相匹配的价格&库存,您可以联系我们找货
