83CNQ080
83CNQ080
    SMCDIODESOLUTIONS(桑德斯)
    PRM2
83CNQ080 数据手册
83CNQ SERIES Technical Data Data Sheet N1062, Rev. - Green Products 83CNQ080/83CNQ100 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 175℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 83CNQ… Case Styles 83CNQ…SL 83CNQ…SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 83CNQ SERIES Technical Data Data Sheet N1062, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 83CNQ080/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 83CNQ080/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 83CNQ SERIES Technical Data Data Sheet N1062, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 83CNQ080 PRM2 48pcs / box 83CNQ080S PRM2 Nickel plated Pure Sn dipped (dipped height 6-8 mm) 83CNQ080SL PRM2-SL Pure Sn plated 100pcs / box 83CNQ080SM PRM2-SM Nickel plated 48pcs / box 83CNQ080SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 83CNQ100 PRM2 Nickel plated 48pcs / box 83CNQ100S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 83CNQ100SL PRM2-SL Pure Sn plated 100pcs / box 83CNQ100SM PRM2-SM Nickel plated 48pcs / box 83CNQ100SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current(per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRRM VRWM VR Condition Max. Units - 80 (83CNQ080) 100(83CNQ100) V IF(AV) 50% duty cycle @TC =132°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 860 A EAS TJ=25℃,IAS=1A,L=30mH 15 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 8 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 83CNQ SERIES Technical Data Data Sheet N1062, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.76 0.81 0.60 0.69 0.0004 1.8 Max. 0.81 1.00 0.67 0.82 1.5 35 Units 1200 1400 pF 5.5 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
83CNQ080 价格&库存
很抱歉,暂时无法提供与“83CNQ080”相匹配的价格&库存,您可以联系我们找货
83CNQ080
  • 1+218.347781+28.28368
