88CNQ060
Technical Data
Data Sheet N1154, Rev. -
Green Products
88CNQ060 SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
175℃ TJ operation
Center tap module
Very Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Low profile, high current package
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
88CNQ060
Case Styles
88CNQ060SL
88CNQ060SM
PRM2
PRM2-SL
PRM2-SM
Mechanical Dimensions: In Inches / mm
PRM2
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
88CNQ060
Technical Data
Green Products
PRM2-SL
PRM2-SM
MARKING, MOLDING RESIN
st
nd
Marking for 88CNQ060/SL/SM, 1 row SS YYWWL, 2
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL: 94V-0
rd
row 88CNQ060/SL/SM, 3 row 1 2 3 (pin)
88CNQ060
Technical Data
Green Products
Ordering Information:
Device
Package
Terminals finish
Shipping
88CNQ060
PRM2
Nickel plated
48pcs / box
88CNQ060S
PRM2
Pure Sn dipped
(dipped height 6-8 mm)
48pcs / box
88CNQ060SL
PRM2-SL
Pure Sn plated
100pcs / box
88CNQ060SM
PRM2-SM
Nickel plated
48pcs / box
88CNQ060SMS
PRM2-SM
Pure Sn dipped
48pcs / box
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current
Peak One Cycle Non-Repetitive
Surge Current
(per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Current(peg leg)
Symbol
VRRM
VRWM
VR
Condition
Max.
Units
60
V
IF(AV)
50% duty cycle @TC =95°C,
rectangular wave form
80
A
IFSM
8.3 ms, half Sine pulse
720
A
EAS
TJ=25℃,IAS=1A,L=0.57mH
75
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×VR
typical
1
A
88CNQ060
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Series Inductance
(per leg)
Voltage Rate of Change
IR1
IR2
CT
LS
dv/dt
Condition
@ 40A, Pulse, TJ = 25 °C
@ 80A, Pulse, TJ = 25 °C
@ 40A, Pulse, TJ = 125 °C
@ 80A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Typ.
0.45
0.60
0.51
0.54
0.4
200
Max.
0.58
0.77
0.56
0.67
0.64
240
Units
2000
5200
pF
5.5
nH
10,000
V/μs
Specification
-55 to +175
-55 to +175
Units
°C
°C
V
V
mA
mA
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“88CNQ060”相匹配的价格&库存,您可以联系我们找货
