83CNQ SERIES
Technical Data
Data Sheet N1062, Rev. -
Green Products
83CNQ080/83CNQ100 SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
175℃ TJ operation
Center tap module
Very Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Low profile, high current package
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
83CNQ…
Case Styles
83CNQ…SL
83CNQ…SM
PRM2
PRM2-SL
PRM2-SM
Mechanical Dimensions: In Inches / mm
PRM2
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
83CNQ SERIES
Technical Data
Green Products
PRM2-SL
PRM2-SM
MARKING, MOLDING RESIN
st
nd
Marking for 83CNQ080/SL/SM, 1 row SS YYWWL, 2
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL: 94V-0
rd
row 83CNQ080/SL/SM, 3 row 1 2 3 (pin)
83CNQ SERIES
Technical Data
Green Products
Ordering Information:
Device
Package
Terminals finish
Shipping
83CNQ080
PRM2
48pcs / box
83CNQ080S
PRM2
Nickel plated
Pure Sn dipped
(dipped height 6-8 mm)
83CNQ080SL
PRM2-SL
Pure Sn plated
100pcs / box
83CNQ080SM
PRM2-SM
Nickel plated
48pcs / box
83CNQ080SMS
PRM2-SM
Pure Sn dipped
48pcs / box
83CNQ100
PRM2
Nickel plated
48pcs / box
83CNQ100S
PRM2
Pure Sn dipped
48pcs / box
83CNQ100SL
PRM2-SL
Pure Sn plated
100pcs / box
83CNQ100SM
PRM2-SM
Nickel plated
48pcs / box
83CNQ100SMS
PRM2-SM
Pure Sn dipped
48pcs / box
48pcs / box
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current
Peak One Cycle Non-Repetitive
Surge Current(per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Current(peg leg)
Symbol
VRRM
VRWM
VR
Condition
Max.
Units
80 (83CNQ080)
100(83CNQ100)
V
IF(AV)
50% duty cycle @TC =132°C,
rectangular wave form
80
A
IFSM
8.3 ms, half Sine pulse
860
A
EAS
TJ=25℃,IAS=1A,L=30mH
15
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×
VR typical
8
A
83CNQ SERIES
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Voltage Rate of Change
IR1
IR2
CT
LS
dv/dt
Condition
@ 40A, Pulse, TJ = 25 °C
@ 80A, Pulse, TJ = 25 °C
@ 40A, Pulse, TJ = 125 °C
@ 80A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Typ.
0.76
0.81
0.60
0.69
0.0004
1.8
Max.
0.81
1.00
0.67
0.82
1.5
35
Units
1200
1400
pF
5.5
nH
10,000
V/μs
V
V
mA
mA
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“83CNQ100SM”相匹配的价格&库存,您可以联系我们找货
