89CNQ135SM
89CNQ135SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SM
89CNQ135SM 数据手册
89CNQ SERIES Technical Data Data Sheet N1135, Rev. - Green Products ULTRA LOW REVERSE LEAKAGE PLASTIC POWER SCHOTTKY RECTIFIER (135V-150V, 80A) Applications: ● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection Features: • • • • • • • • • • • 175℃ TJ operation Ultra low reverse leakage current Soft reverse recovery at low and high temperature Low forward voltage drop Low power loss, high efficiency High surge capacity Guard ring for enhanced ruggedness and long term reliability Guaranteed reverse avalanche characteristics This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 89CNQ… Case Styles 89CNQ…SL 89CNQ…SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 89CNQ SERIES Technical Data Data Sheet N1135, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 89CNQ135/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 89CNQ135/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 89CNQ SERIES Technical Data Data Sheet N1135, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 89CNQ135 PRM2 Nickel plated 48pcs / box 89CNQ135S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 89CNQ135SL PRM2-SL Pure Sn plated 100pcs / box 89CNQ135SM PRM2-SM Nickel plated 48pcs / box 89CNQ135SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 89CNQ150 PRM2 Nickel plated 48pcs / box 89CNQ150S PRM2 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 89CNQ150SL PRM2-SL Pure Sn plated 100pcs / box 89CNQ150SM PRM2-SM Nickel plated 48pcs / box 89CNQ150SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition Max. Units - 135(89CNQ135) 150(89CNQ150) V Average Forward Current IF(AV) 50% duty cycle @TC =132°C, rectangular wave form 80 A Peak One Cycle Non-Repetitive Surge Current(per leg) IFSM 8.3 ms, half Sine pulse 708 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 89CNQ SERIES Technical Data Data Sheet N1135, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz, VSIG=50mV(p-p) Measured lead to lead 5 mm from package body - Typ. 0.82 0.88 0.62 0.72 0.02 4 Max. 0.99 1.14 0.69 0.78 1.5 21 Units 1200 1400 pF 5.5 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
89CNQ135SM
1. 物料型号: - 89CNQ135:PRM2封装,镍镀层,每盒48个。 - 89CNQ135S:PRM2封装,纯锡浸镀(浸镀高度6-8mm),每盒48个。 - 89CNQ135SL:PRM2-SL封装,纯锡镀层,每盒100个。 - 89CNQ135SM:PRM2-SM封装,镍镀层,每盒48个。 - 89CNQ135SMS:PRM2-SM封装,纯锡浸镀(浸镀高度6-8mm),每盒48个。 - 89CNQ150:PRM2封装,镍镀层,每盒48个。 - 89CNQ150S:PRM2封装,纯锡浸镀(浸镀高度6-8mm),每盒48个。 - 89CNQ150SL:PRM2-SL封装,纯锡镀层,每盒100个。 - 89CNQ150SM:PRM2-SM封装,镍镀层,每盒48个。 - 89CNQ150SMS:PRM2-SM封装,纯锡浸镀(浸镀高度6-8mm),每盒48个。
2. 器件简介: - 89CNQ系列是超低反向漏电塑料功率肖特基整流器,工作电压范围为135V-150V,平均正向电流为80A。
3. 引脚分配: - 引脚1:阳极1(ANODE1) - 引脚2:阳极2(ANODE2) - 引脚3:共阴极基座(COMMON CATHODE BASE)
4. 参数特性: - 工作结温(Tj):175℃ - 超低反向漏电电流 - 软反向恢复特性 - 低正向电压降 - 高效率、低功耗 - 高浪涌能力 - 增强的鲁棒性和长期可靠性 - 保证的反向雪崩特性
5. 功能详解: - 该系列器件为无铅产品,所有SMC零件都可以追溯到晶圆批次。可以根据要求提供额外测试。
6. 应用信息: - 开关电源 - 转换器 - 自由轮二极管 - 反向电池保护
7. 封装信息: - PRM2、PRM2-SL、PRM2-SM封装风格,具体尺寸和机械尺寸以英寸/毫米标注。
89CNQ135SM 价格&库存
很抱歉,暂时无法提供与“89CNQ135SM”相匹配的价格&库存,您可以联系我们找货
