86CNQ200SM
86CNQ200SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SM
86CNQ200SM 数据手册
86CNQ200 Technical Data Data Sheet N1133, Rev. - Green Products 86CNQ200 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 175℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 86CNQ200 Case Styles 86CNQ200SL 86CNQ200SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 86CNQ200 Technical Data Data Sheet N1133, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 86CNQ200/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 86CNQ200/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 86CNQ200 Technical Data Data Sheet N1133, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 86CNQ200 PRM2 48pcs / box 86CNQ200S PRM2 Nickel plated Pure Sn dipped (dipped height 6-8 mm) 86CNQ200SL PRM2-SL Pure Sn plated 100pcs / box 86CNQ200SM PRM2-SM Nickel plated 48pcs / box 86CNQ200SMS PRM2-SM Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition Max. Units - 200 V IF(AV) 50% duty cycle @TC =130°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 86CNQ200 Technical Data Data Sheet N1133, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.83 0.68 0.0002 0.3 Max. 0.99 1.14 0.69 0.78 1.1 24 Units 750 900 pF 5.5 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
86CNQ200SM 价格&库存
很抱歉,暂时无法提供与“86CNQ200SM”相匹配的价格&库存,您可以联系我们找货
