SANGDEST
MICROELECTRONICS
84CNQ060
Technical Data
Data Sheet N1153, Rev. -
Green Products
84CNQ060 SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
125℃ TJ operation
Center tap module
Very Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Low profile, high current package
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
84CNQ060
Case Styles
84CNQ060SL
84CNQ060SM
PRM2
PRM2-SL
PRM2-SM
Mechanical Dimensions: In Inches / mm
PRM2
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
84CNQ060
Technical Data
Green Products
PRM2-SL
PRM2-SM
MARKING, MOLDING RESIN
st
nd
Marking for 84CNQ060/SL/SM, 1 row SS YYWWL, 2
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL: 94V-0
rd
row 84CNQ060/SL/SM, 3 row 1 2 3 (pin)
SANGDEST
MICROELECTRONICS
84CNQ060
Technical Data
Green Products
Maximum Ratings:
Characteristics
Symbol
Condition
Max.
Units
Peak Inverse Voltage
VRWM
60
V
Max. Average Forward
IF(AV)
50% duty cycle @TC =91°C,
rectangular wave form
80
A
IFSM
8.3 ms, half Sine pulse
750
A
EAS
TJ=25℃,IAS=8A,L=18mH
54
mJ
IAR
Current decaying linearly to zero
in 1 μsec Frequency limited by
TJ max. VA=1.5×VR typical
8
A
Max.
0.49
0.62
0.44
0.60
5
600
Units
2600
pF
5.5
nH
10,000
V/μs
Specification
-55 to +125
-55 to +125
Units
°C
°C
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Non-Repetitive
Avalanche
Energy(peg leg)
Repetitive
Current(peg leg)
Avalanche
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Max. Reverse Current (per
leg) *
Max. Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
IR1
IR2
CT
LS
dv/dt
Condition
@ 40A, Pulse, TJ = 25 °C
@ 80A, Pulse, TJ = 25 °C
@ 40A, Pulse, TJ = 100 °C
@ 80A, Pulse, TJ = 100 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
V
V
mA
mA
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“84CNQ060SM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1056+140.980381056+18.32076
