87CNQ020SL
87CNQ020SL
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SL
87CNQ020SL 数据手册
SANGDEST MICROELECTRONICS 87CNQ020 Technical Data Data Sheet N1134, Rev. - Green Products 87CNQ020 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 87CNQ020 Case Styles 87CNQ020SL 87CNQ020SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 87CNQ020 Technical Data Data Sheet N1134, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 87CNQ020/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 87CNQ020/SL/SM, 3 row 1 2 3 (pin) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 87CNQ020 Technical Data Data Sheet N1134, Rev. - Green Products Maximum Ratings: Characteristics Symbol Condition Max. Units Peak Inverse Voltage VRWM - 20 V Max. Average Forward IF(AV) 50% duty cycle @TC =135°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 1320 A EAS TJ=25℃,IAS=8A,L=1.12mH 36 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 8 A Max. 0.45 0.51 0.32 0.39 5.5 550 Units 6500 pF 5.5 nH 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Current(peg leg) Avalanche Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - V V mA mA Pulse Width < 300µs, Duty Cycle
87CNQ020SL
物料型号: - 型号:87CNQ020 - 封装类型:PRM2, PRM2-SL, PRM2-SM
器件简介: - 87CNQ020是一款Schottky整流器,适用于开关电源、转换器、自由轮流通路二极管和反向电池保护等应用。
引脚分配: - 引脚1和引脚2为阳极(ANODE1, ANODE2) - 引脚3为共阴极(COMMON CATHODE BASE)
参数特性: - 最大反向峰值电压(VRWM):20V - 最大平均正向电流(IF(AV)):80A(50%占空比,Tc=135°C时为矩形波形) - 最大单周期非重复浪涌电流(IFSM):1320A(8.3ms,半正弦脉冲) - 非重复雪崩能量(EAS):36mJ(T=25°C,IAs=8A,L=1.12mH) - 雪崩重复电流(IAR):8A(电流在1微秒内线性衰减至零,频率受Tmax限制,VA=1.5XVR典型值)
功能详解: - 工作结温达到150°C - 中心抽头模块 - 非常低的正向电压降 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 适用于高频操作 - 保护环增强了坚固性和长期可靠性 - 低轮廓、大电流封装
应用信息: - 适用于开关电源、转换器、自由轮流通路二极管和反向电池保护等应用。
封装信息: - 封装类型包括PRM2、PRM2-SL和PRM2-SM,具体尺寸和机械尺寸在文档中有详细描述。
87CNQ020SL 价格&库存
很抱歉,暂时无法提供与“87CNQ020SL”相匹配的价格&库存,您可以联系我们找货
