84CNQ060SL
84CNQ060SL
    SMCDIODESOLUTIONS(桑德斯)
    PRM2-SL
84CNQ060SL 数据手册
SANGDEST MICROELECTRONICS 84CNQ060 Technical Data Data Sheet N1153, Rev. - Green Products 84CNQ060 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 125℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 84CNQ060 Case Styles 84CNQ060SL 84CNQ060SM PRM2 PRM2-SL PRM2-SM Mechanical Dimensions: In Inches / mm PRM2 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 84CNQ060 Technical Data Data Sheet N1153, Rev. - Green Products PRM2-SL PRM2-SM MARKING, MOLDING RESIN st nd Marking for 84CNQ060/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 84CNQ060/SL/SM, 3 row 1 2 3 (pin) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 84CNQ060 Technical Data Data Sheet N1153, Rev. - Green Products Maximum Ratings: Characteristics Symbol Condition Max. Units Peak Inverse Voltage VRWM - 60 V Max. Average Forward IF(AV) 50% duty cycle @TC =91°C, rectangular wave form 80 A IFSM 8.3 ms, half Sine pulse 750 A EAS TJ=25℃,IAS=8A,L=18mH 54 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 8 A Max. 0.49 0.62 0.44 0.60 5 600 Units 2600 pF 5.5 nH 10,000 V/μs Specification -55 to +125 -55 to +125 Units °C °C Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Current(peg leg) Avalanche Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 100 °C @ 80A, Pulse, TJ = 100 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - V V mA mA Pulse Width < 300µs, Duty Cycle
84CNQ060SL 价格&库存
很抱歉,暂时无法提供与“84CNQ060SL”相匹配的价格&库存,您可以联系我们找货
