DSA120X200LB
preliminary
Schottky Diode Gen ²
VRRM
200 V
I FAV
= 2x
VF
65 A
0.82 V
High Performance Schottky Diode
Low Loss and Soft Recovery
Parallel legs
Part number
DSA120X200LB
Marking on Product: DSA120X200LB
Backside: isolated
7
8 = n/c
9
6
5
4
3
2
1
Features / Advantages:
Applications:
Package: SMPD
● Very low Vf
● Extremely low switching losses
● Low Irm values
● Improved thermal behaviour
● High reliability circuit operation
● Low voltage peaks for reduced
protection circuits
● Low noise switching
● Rectifiers in switch mode power
supplies (SMPS)
● Free wheeling diode in low voltage
converters
● Isolation Voltage: 3000 V~
● Industry convenient outline
● RoHS compliant
● Epoxy meets UL 94V-0
● Soldering pins for PCB mounting
● Backside: DCB ceramic
● Reduced weight
● Advanced power cycling
Disclaimer Notice
Information furnished is believed to be accurate and reliable. However, users should independently
evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for,
and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics.
IXYS reserves the right to change limits, conditions and dimensions.
© 2019 IXYS all rights reserved
Data according to IEC 60747and per semiconductor unless otherwise specified
20190212b
DSA120X200LB
preliminary
Ratings
Schottky
Conditions
Symbol
VRSM
Definition
max. non-repetitive reverse blocking voltage
TVJ = 25°C
VRRM
max. repetitive reverse blocking voltage
TVJ = 25°C
200
V
IR
reverse current, drain current
VF
forward voltage drop
min.
typ.
VR = 200 V
TVJ = 25°C
1
mA
VR = 200 V
TVJ = 125°C
5
mA
IF =
TVJ = 25°C
0.98
V
1.22
V
0.82
V
60 A
I F = 120 A
IF =
TVJ = 150 °C
60 A
I F = 120 A
I FAV
average forward current
VF0
threshold voltage
rF
slope resistance
R thJC
thermal resistance junction to case
TC = 130 °C
rectangular
1.10
V
T VJ = 175 °C
65
A
TVJ = 175 °C
0.51
V
2.7
mΩ
d = 0.5
for power loss calculation only
0.8 K/W
R thCH
thermal resistance case to heatsink
Ptot
total power dissipation
I FSM
max. forward surge current
t = 10 ms; (50 Hz), sine; VR = 0 V
TVJ = 45°C
CJ
junction capacitance
VR =
TVJ = 25°C
max. Unit
200
V
K/W
0.40
TC = 25°C
24 V f = 1 MHz
185
700
394
W
A
pF
20190212b
DSA120X200LB
preliminary
Package
Ratings
SMPD
Symbol
I RMS
Definition
Conditions
RMS current
per terminal
min.
TVJ
virtual junction temperature
T op
operation temperature
Tstg
storage temperature
-55
max.
100
Unit
A
-55
175
°C
-55
150
°C
150
°C
8.5
Weight
FC
40
mounting force with clip
d Spp/App
t = 1 minute
UL Logo
Assembly line
N
mm
terminal to backside
4.0
mm
3000
V
2500
V
50/60 Hz, RMS; IISOL ≤ 1 mA
Part description
D
S
A
120
X
200
LB
Backside DCB
Part number
Date code
130
1.6
t = 1 second
isolation voltage
g
terminal to terminal
creepage distance on surface | striking distance through air
d Spb/Apb
VISOL
typ.
XXXXXXXXXX
yywwA
Diode
Schottky Diode
low VF
Current Rating [A]
Parallel legs
Reverse Voltage [V]
SMPD-B
Data Matrix Code
Digits
1 to 19:
20 to 23:
24 to 25:
26 to 31:
32:
33 to 36:
Part #
Date Code
Assembly line
Lot #
Split Lot
Individual #
Pin 1 identifier
Ordering
Standard
Alternative
Ordering Number
DSA120X200LB-TUB
DSA120X200LB-TRR
Equivalent Circuits for Simulation
I
V0
R0
Marking on Product
DSA120X200LB
DSA120X200LB
* on die level
Delivery Mode
Tube
Tape & Reel
Code No.
524773
523115
T VJ = 175 °C
Schottky
V 0 max
threshold voltage
0.51
V
R0 max
slope resistance *
2.7
mΩ
Quantity
20190212b
DSA120X200LB
preliminary
Outlines SMPD
A(8:1)
2)
5,5 `0,1
(6x) 1 `0,05
0 + 0,15
2°
c 0,1
0,5 ` 0,1
1)
18 `0,1
seating plane
(3x) 2 `0,05
9 `0,1
2)
4 `0,05
8
9
32,7 ` 0,5
23 `0,2
2 `0,2
7
0,55 `0,1
4,85 ` 0,2
25 `0,2
3)
c 0,05
6 5 4
A
3 2 1
Pin number
2,75 `0,1
5,5 ` 0,1
13,5 ` 0,1
16,25 `0,1
19 `0,1
Notes:
1) potrusion may add 0.2 mm max. on each side
2) additional max. 0.05 mm per side by punching misalignement
or overlap of dam bar or bending compression
3) DCB area 10 to 50 µm convex;
position of DCB area in relation to plastic rim: ±25 µm
(measured 2 mm from Cu rim)
4) terminal plating: 0.2 - 1 µm Ni + 10 - 25 µm Sn (gal v.)
cutting edges may be partially free of plating
7
8 = n/c
9
6
5
4
3
2
1
20190212b
很抱歉,暂时无法提供与“DSA120X200LB-TRR”相匹配的价格&库存,您可以联系我们找货
