69CNQ135
69CNQ150
Technical Data
Data Sheet N1057, Rev. -
Green Products
69CNQ135/69CNQ150 SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
175℃ TJ operation
Center tap module
Very Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Low profile, high current package
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
69CNQ…
Case Styles
69CNQ…SL
69CNQ…SM
PRM3
PRM3-SL
PRM3-SM
Mechanical Dimensions: In Inches / mm
PRM3
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
69CNQ135
69CNQ150
Technical Data
Green Products
PRM3-SL
PRM3-SM
MARKING, MOLDING RESIN
st
nd
Marking for 69CNQ135/SL/SM, 1 row SS YYWWL, 2
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL: 94V-0
rd
row 69CNQ135/SL/SM, 3 row 1 2 3 (pin)
69CNQ135
69CNQ150
Technical Data
Green Products
Ordering Information:
Device
Package
Terminals finish
Shipping
69CNQ135
PRM3
Nickel plated
48pcs / box
69CNQ135S
PRM3
Pure Sn dipped
(dipped height 6-8 mm)
48pcs / box
69CNQ150
PRM3
Nickel plated
48pcs / box
69CNQ150S
PRM3
Pure Sn dipped
48pcs / box
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current
Peak One Cycle Non-Repetitive
Surge Current
(per leg)
Symbol
VRRM
VRWM
VR
Condition
Max.
Units
135(69CNQ135)
150(69CNQ150)
V
IF(AV)
50% duty cycle @TC =155°C,
rectangular wave form
60
A
IFSM
8.3 ms, half Sine pulse
150
A
69CNQ135
69CNQ150
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg)*
Reverse Current (per leg)*
Junction Capacitance
(per leg)
Series Inductance
(per leg)
Voltage Rate of Change
Symbol
VF1
VF2
IR1
IR2
CT
LS
dv/dt
Condition
@ 30A, Pulse, TJ = 25 °C
@ 30A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Typ.
0.75
0.60
0.0002
0.4
Max.
0.87
0.67
1.5
Units
V
V
mA
mA
1200
1300
pF
6.0
6.0
nH
10,000
V/μs
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“69CNQ135SL”相匹配的价格&库存,您可以联系我们找货
