61CNQ045
61CNQ045
    SMCDIODESOLUTIONS(桑德斯)
    PRM3
61CNQ045 数据手册
61CNQ SERIES Technical Data Data Sheet N1031, Rev. - Green Products 61CNQ035/61CNQ040/61CNQ045 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 175℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 61CNQ… Case Styles 61CNQ…SL 61CNQ…SM PRM3 PRM3-SL PRM3-SM Mechanical Dimensions: In Inches / mm PRM3 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 61CNQ SERIES Technical Data Data Sheet N1031, Rev. - Green Products PRM3-SL PRM3-SM MARKING, MOLDING RESIN st nd Marking for 61CNQ035/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 61CNQ035/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 61CNQ SERIES Technical Data Data Sheet N1031, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 61CNQ035 PRM3 Nickel plated 48pcs / box 61CNQ035S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 61CNQ040 PRM3 Nickel plated 48pcs / box 61CNQ040S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 61CNQ045 PRM3 Nickel plated 48pcs / box 61CNQ045S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRRM VRWM VR Condition - Max. 35(61CNQ035) 40(61CNQ040) 45(61CNQ045) Units V IF(AV) 50% duty cycle @TC =149°C, rectangular wave form 60 A IFSM 8.3 ms, half Sine pulse 990 A EAS TJ=25℃,IAS=6A,L=2.2mH 40 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 6 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 61CNQ SERIES Technical Data Data Sheet N1031, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 30A, Pulse, TJ = 25 °C @ 60A, Pulse, TJ = 25 °C @ 30A, Pulse, TJ = 125 °C @ 60A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.51 0.56 0.43 0.50 0.03 25 Max. 0.61 0.68 0.49 0.60 5 45 Units 2300 2600 pF 6.0 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
61CNQ045 价格&库存
很抱歉,暂时无法提供与“61CNQ045”相匹配的价格&库存,您可以联系我们找货
