63CNQ080SM
63CNQ080SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM3-SM
63CNQ080SM 数据手册
63CNQ SERIES Technical Data Data Sheet N1054, Rev. - Green Products 63CNQ080/63CNQ100 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 175℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 63CNQ… Case Styles 63CNQ…SL 63CNQ…SM PRM3 PRM3-SL PRM3-SM Mechanical Dimensions: In Inches / mm PRM3 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 63CNQ SERIES Technical Data Data Sheet N1054, Rev. - Green Products PRM3-SL PRM3-SM MARKING, MOLDING RESIN st nd Marking for 63CNQ080/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 63CNQ080/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 63CNQ SERIES Technical Data Data Sheet N1054, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 63CNQ080 PRM3 Nickel plated 48pcs / box 63CNQ080S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 63CNQ100 PRM3 Nickel plated 48pcs / box 63CNQ100S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRRM VRWM VR Condition Max. Units - 80(63CNQ080) 100(63CNQ100) V IF(AV) 50% duty cycle @TC =155°C, rectangular wave form 60 A IFSM 8.3 ms, half Sine pulse 750 A EAS TJ=25℃,IAS=1A,L=30mH 15 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 1 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 63CNQ SERIES Technical Data Data Sheet N1054, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 30A, Pulse, TJ = 25 °C @ 60A, Pulse, TJ = 25 °C @ 30A, Pulse, TJ = 125 °C @ 60A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.73 0.79 0.58 0.63 0.005 1.5 Max. 0.80 0.93 0.64 0.76 1.5 20 Units 1200 1400 pF 6.0 - nH - 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
63CNQ080SM
物料型号为63CNQ080/63CNQ100,属于63CNQ系列肖特基整流器。
器件简介:这款肖特基整流器主要用于开关电源、转换器、自由轮流通二极管和反向电池保护。
它具有175℃的TJ操作温度,中心抽头模块设计,极低的正向电压降,高纯度、耐高温的环氧树脂封装以增强机械强度和抗湿性,高频率操作能力,以及增强的抗冲击性和长期可靠性。
引脚分配:引脚编号为1、2、3,分别对应ANODE1、ANODE2和REF。
参数特性: - 峰值重复反向电压:80V(63CNQ080)/100V(63CNQ100) - 平均整流正向电流:60A(50%占空比,Tc=155°C,矩形波形) - 峰值单周期非重复浪涌电流:750A(8.3ms,半正弦脉冲) - 非重复雪崩能量:15mJ(T=25°C,IAs=1A,L=30mH) - 重复雪崩电流:1A(电流在1微秒内线性衰减至零,频率由T,max.VA=1.5X VR典型值限制)
功能详解:这款肖特基整流器具有低正向电压降和高效率的特点,适用于高频开关电源和转换器。
它还具有反向电池保护功能,可以在电池反接时保护电路不受损害。
此外,它还具有很好的热性能和可靠性,适用于需要高可靠性的应用场合。
应用信息:适用于开关电源、转换器、自由轮流通二极管和反向电池保护等应用。
封装信息:有三种封装方式,分别为PRM3、PRM3-SL和PRM3-SM。
封装尺寸和引脚镀层信息如下: - 63CNQ080:PRM3封装,镍镀层,每盒48个 - 63CNQ080S:PRM3封装,纯锡浸镀层(浸镀高度6-8mm),每盒48个 - 63CNQ100:PRM3封装,镍镀层,每盒48个 - 63CNQ100S:PRM3封装,纯锡浸镀层(浸镀高度6-8mm),每盒48个
关于胶带和卷轴规格的详细信息,包括零件方向和胶带尺寸,请参阅SMC的胶带和卷轴包装规格。
63CNQ080SM 价格&库存
很抱歉,暂时无法提供与“63CNQ080SM”相匹配的价格&库存,您可以联系我们找货
