69CNQ150SM
69CNQ150SM
    SMCDIODESOLUTIONS(桑德斯)
    PRM3-SM
69CNQ150SM 数据手册
69CNQ135 69CNQ150 Technical Data Data Sheet N1057, Rev. - Green Products 69CNQ135/69CNQ150 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 175℃ TJ operation Center tap module Very Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Low profile, high current package This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request 69CNQ… Case Styles 69CNQ…SL 69CNQ…SM PRM3 PRM3-SL PRM3-SM Mechanical Dimensions: In Inches / mm PRM3 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 69CNQ135 69CNQ150 Technical Data Data Sheet N1057, Rev. - Green Products PRM3-SL PRM3-SM MARKING, MOLDING RESIN st nd Marking for 69CNQ135/SL/SM, 1 row SS YYWWL, 2 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 rd row 69CNQ135/SL/SM, 3 row 1 2 3 (pin) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 69CNQ135 69CNQ150 Technical Data Data Sheet N1057, Rev. - Green Products Ordering Information: Device Package Terminals finish Shipping 69CNQ135 PRM3 Nickel plated 48pcs / box 69CNQ135S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box 69CNQ150 PRM3 Nickel plated 48pcs / box 69CNQ150S PRM3 Pure Sn dipped (dipped height 6-8 mm) 48pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition Max. Units - 135(69CNQ135) 150(69CNQ150) V IF(AV) 50% duty cycle @TC =155°C, rectangular wave form 60 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 69CNQ135 69CNQ150 Technical Data Data Sheet N1057, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Condition @ 30A, Pulse, TJ = 25 °C @ 30A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.75 0.60 0.0002 0.4 Max. 0.87 0.67 1.5 20 Units V V mA mA 1200 1300 pF 6.0 6.0 nH - 10,000 V/μs Pulse Width < 300µs, Duty Cycle
69CNQ150SM 价格&库存
很抱歉,暂时无法提供与“69CNQ150SM”相匹配的价格&库存,您可以联系我们找货
