DSEP2X31-06B
DSEP2X31-06B
    IXYSCORPORATION
    SOT-227
    DIODE MODULE 600V 30A SOT227B
DSEP2X31-06B 数据手册
DSEP2x31-06A HiPerFRED VRRM = I FAV = 2x 30 A t rr = 35 ns 600 V High Performance Fast Recovery Diode Low Loss and Soft Recovery Parallel legs Part number DSEP2x31-06A Backside: isolated 2 1 3 4 Features / Advantages: Applications: Package: SOT-227B (minibloc) ● Planar passivated chips ● Very low leakage current ● Very short recovery time ● Improved thermal behaviour ● Very low Irm-values ● Very soft recovery behaviour ● Avalanche voltage rated for reliable operation ● Soft reverse recovery for low EMI/RFI ● Low Irm reduces: - Power dissipation within the diode - Turn-on loss in the commutating switch ● Antiparallel diode for high frequency switching devices ● Antisaturation diode ● Snubber diode ● Free wheeling diode ● Rectifiers in switch mode power supplies (SMPS) ● Uninterruptible power supplies (UPS) ● Isolation Voltage: 3000 V~ ● Industry standard outline ● RoHS compliant ● Epoxy meets UL 94V-0 ● Base plate: Copper internally DCB isolated ● Advanced power cycling Disclaimer Notice Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for, and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics. IXYS reserves the right to change limits, conditions and dimensions. © 2022 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20220608d DSEP2x31-06A Ratings Fast Diode Conditions Symbol VRSM max. non-repetitive reverse blocking voltage TVJ = 25°C VRRM max. repetitive reverse blocking voltage TVJ = 25°C 600 IR reverse current, drain current VR = 600 V TVJ = 25°C 250 µA VR = 600 V TVJ = 150°C 1 mA TVJ = 25°C 1,58 V 1,88 V 1,23 V VF Definition IF = forward voltage drop I FAV average forward current VF0 threshold voltage rF slope resistance R thJC thermal resistance junction to case min. 30 A IF = 60 A IF = 30 A IF = 60 A typ. TVJ = 150 °C TC = 100°C rectangular max. Unit 600 V V 1,48 V T VJ = 150 °C 30 A TVJ = 150 °C 0,98 V 8,2 mΩ d = 0.5 for power loss calculation only 1,15 K/W K/W R thCH thermal resistance case to heatsink Ptot total power dissipation I FSM max. forward surge current t = 10 ms; (50 Hz), sine; VR = 0 V TVJ = 45°C CJ junction capacitance VR = 400 V f = 1 MHz TVJ = 25°C 26 pF I RM max. reverse recovery current TVJ = 25 °C 12 A t rr reverse recovery time IXYS reserves the right to change limits, conditions and dimensions. © 2022 IXYS all rights reserved 0,1 TC = 25°C I F = 30 A; VR = 300 V -di F /dt = 400 A/µs 100 250 W A TVJ = 100°C 20 A TVJ = 25 °C 30 ns TVJ = 100°C 90 ns Data according to IEC 60747and per semiconductor unless otherwise specified 20220608d DSEP2x31-06A Package Ratings SOT-227B (minibloc) Symbol I RMS Definition Conditions RMS current per terminal TVJ virtual junction temperature T op operation temperature Tstg storage temperature -40 min. typ. max. 100 Unit A -40 150 °C -40 125 °C 150 °C 30 Weight MD MT d Spp/App d Spb/Apb VISOL g mounting torque 1,1 1,5 Nm terminal torque 1,1 1,5 Nm creepage distance on surface | striking distance through air terminal to terminal 10,5 terminal to backside 8,6 t = 1 second isolation voltage t = 1 minute 50/60 Hz, RMS; IISOL ≤ 1 mA 3,2 mm 6,8 mm 3000 V 2500 V Product Marking Logo Date Code yywwZ ® XXXXX 123456 Location UL Ordering Standard Part Number Lot# Ordering Number DSEP2x31-06A Similar Part DSEP2x31-06B Equivalent Circuits for Simulation I V0 R0 Marking on Product DSEP2x31-06A Package SOT-227B (minibloc) * on die level Delivery Mode Tube Code No. 473928 Voltage class 600 T VJ = 150 °C Fast Diode V 0 max threshold voltage 0,98 V R 0 max slope resistance * 6,3 mΩ IXYS reserves the right to change limits, conditions and dimensions. © 2022 IXYS all rights reserved Quantity 10 Data according to IEC 60747and per semiconductor unless otherwise specified 20220608d DSEP2x31-06A Outlines SOT-227B (minibloc) 2 1 3 4 IXYS reserves the right to change limits, conditions and dimensions. © 2022 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20220608d DSEP2x31-06A Fast Diode 70 3000 60 50 TVJ = 100°C TVJ = 100°C VR = 300 V 2500 VR = 300 V 40 50 IF = 60 A 2000 IF 40 Qr TVJ = 150°C IF = 60 A 1500 100°C 25°C [A] 30 IRM 30 30 A 15 A [nC] 30 A 15 A [A] 20 1000 20 10 500 10 0 0.0 0.5 1.0 1.5 0 100 2.0 0 1000 VF [V] Fig. 1 Forward current IF vs. VF 200 130 IF = 60 A 110 30 A 15 A IRM 1000 20 1.2 15 0.9 VFR trr TVJ = 100°C 10 100 [ns] 800 VR = 300 V 1.5 Kf 1.0 600 Fig. 3 Peak reverse current IRM versus -diF /dt TVJ = 100°C 120 trr 400 -diF /dt [A/μs] Fig. 2 Reverse recovery charge Qr versus -diF /dt 2.0 0.5 0 -diF /dt [A/μs] 0.6 IF = 30 A [V] [μs] 90 5 0.3 VFR 80 tfr Qr 0.0 70 0 40 80 120 160 0 0 TVJ [°C] 200 400 600 800 1000 0 200 400 -diF /dt [A/μs] Fig. 4 Dynamic parameters Qr, IRM versus TVJ 600 800 0.0 1000 -diF /dt [A/μs] Fig. 6 Peak forward voltage VFR and tfr versus diF /dt Fig. 5 Recovery time trr versus -diF /dt 2 1 Constants for ZthJC calculation: 0.1 ZthJC [K/W] 0.01 0.001 0.0001 0.001 0.01 0.1 i Rthi (K/W) 1 0.436 0.0055 2 0.482 0.0092 3 0.117 0.0007 4 0.115 0.0418 ti (s) 1 t [s] Fig. 7 Transient thermal resistance junction to case IXYS reserves the right to change limits, conditions and dimensions. © 2022 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20220608d
DSEP2X31-06B 价格&库存
很抱歉,暂时无法提供与“DSEP2X31-06B”相匹配的价格&库存,您可以联系我们找货
