169CMQ135
169CMQ135
    SMCDIODESOLUTIONS(桑德斯)
    TO-249AA
169CMQ135 数据手册
SANGDEST MICROELECTRONICS 169CMQ…SERIES Technical Data Data Sheet N1239, Rev. - Green Products 169CMQ135/169CMQ150 SCHOTTKY RECTIFIER Applications: • Switching power supply • Converters • Free-Wheeling diodes • Reverse battery protection Features: • • • • • • • • • • • • 150 °C TJ operation Isolated heatsink Multiple leads per terminal for high frequency, high current PC board mounting Low profile, high current package Center tap module Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In Inches / mm TO-249AA MARKING, MOLDING RESIN st nd rd Marking for 169CMQ135/150, 1 row SS YYWWL, 2 row 169CMQ135/150, 3 row 1 2 3 (Pin) Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 169CMQ…SERIES Technical Data Data Sheet N1239, Rev. - Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current * Max. Peak One Cycle NonRepetitive Surge Current (peg leg) Symbol Condition VRWM - 135 Max. 169CMQ135 150 169CMQ150 Units V IF(AV) 50% duty cycle @TC = 87°C, rectangular wave form 160 A IFSM 8.3 ms, half Sine pulse 960 A Condition @ 80A, Pulse, TJ = 25 °C @ 80A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR ,TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 1.05 0.85 1.5 21 Units V V mA mA 1300 pF 8.0 nH 10,000 V/μs Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Pulse Width < 300µs, Duty Cycle
169CMQ135
1. 物料型号: - 169CMQ135/150
2. 器件简介: - 该系列是肖特基整流器,适用于开关电源、转换器、自由轮二极管和反向电池保护等应用。
3. 引脚分配: - 文档中提到了多个引脚,每个引脚对应不同的功能,具体分配如下: - 第1行:SS YYWWL(制造年份和周代码) - 第2行:169CMQ135/150(型号) - 第3行:1 2 3(引脚编号)
4. 参数特性: - 最大反向峰值电压(VRWM):169CMQ135为135V,169CMQ150为150V - 最大平均正向电流(IF(AV)):在87°C下,50%占空比时为160A - 最大单周期非重复浪涌电流(IFSM):8.3ms半正弦脉冲为960A
5. 功能详解: - 150°C TJ操作 - 隔离散热器 - 多个引脚/终端适用于高频、高电流PCB安装 - 低轮廓、高电流封装 - 中心抽头模块 - 低正向电压降 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 高频操作 - 保护环增强耐用性和长期可靠性 - 无铅设备 - 所有SMC部件均可追溯至晶圆批次
6. 应用信息: - 开关电源、转换器、自由轮二极管、反向电池保护
7. 封装信息: - 封装类型:TO-249AA - 封装材料:环氧树脂UL:94V-0
169CMQ135 价格&库存
很抱歉,暂时无法提供与“169CMQ135”相匹配的价格&库存,您可以联系我们找货
169CMQ135
    • 1+320.67360
    • 192+127.94760
    • 504+123.68160
    • 1008+121.56480
