FST10060
FST10060
    GENESICSEMICONDUCTOR
    TO-249AB
FST10060 数据手册
FST10045 thru FST100100 Silicon Power Schottky Diode VRRM = 45 V - 100 V IF(AV) = 100 A Features • High Surge Capability • Types from 45 V to 100V VRRM TO-249AB Package • Isolated to Plate • Not ESD Sensitive Maximum ratings, at Tj = 25 °C, unless otherwise specified FST10045 FST10060 FST10080 FST100100 Unit VRRM 45 60 80 100 V VRMS 32 42 57 70 V 60 -55 to 150 -55 to 150 80 -55 to 150 -55 to 150 100 -55 to 150 -55 to 150 V °C °C Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg Conditions 45 -55 to 150 -55 to 150 Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Symbol Conditions FST10045 FST10060 FST10080 FST100100 Unit Average forward current (per pkg) IF(AV) TC = 125 °C 100 100 100 100 A Peak forward surge current (per leg) IFSM tp = 8.3 ms, half sine 1000 1000 1000 1000 A VF IFM = 50 A, Tj = 25 °C 0.70 0.75 0.84 0.84 V IR Tj = 25 °C Tj = 100 °C Tj = 150 °C 1 10 30 1 10 30 1 10 30 1 10 30 mA 1.0 1.0 1.0 1.0 °C/W Maximum instantaneous forward voltage (per leg) Maximum Instantaneous reverse current at rated DC blocking voltage (per leg) Thermal characteristics Thermal resistance, junction case (per leg) Oct. 2018 RΘJC http://www.diodemodule.com/silicon_products/modules/fst10060.pdf 1 FST10045 thru FST100100 Oct. 2018 http://www.diodemodule.com/silicon_products/modules/fst10060.pdf 2 FST10045 thru FST100100 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. N A P G E C J 1 2 3 B L F K H M R Q D Inches Oct. 2018 Millimeters Min Max Min Max A 1.995 2.005 50.67 50.93 B 0.300 0.325 7.62 8.26 C 0.495 0.505 12.57 12.83 D 0.182 0.192 4.62 4.88 E 0.990 1.010 25.15 26.65 F 2.390 2.410 60.71 61.21 G 1.495 1.525 37.90 38.70 H 0.114 0.122 2.90 3.10 J ----- 0.420 ----- 10.67 K 0.256 0.275 6.5 7.0 L 0.490 0.510 12.45 12.95 M 0.330 0.350 8.38 8.90 N 0.175 0.195 4.45 4.95 P 0.035 0.045 0.89 1.14 R 0.445 0.455 11.30 11.56 Q 0.890 0.910 22.61 23.11 http://www.diodemodule.com/silicon_products/modules/fst10060.pdf 3
FST10060
物料型号为:STM32F103C8T6 器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的 32 位 MCU,具有 64KB 闪存和 20KB SRAM。
引脚分配:包含 81 个引脚,支持多种功能,如 GPIO、ADC、USART、SPI、I2C 等。
参数特性:工作电压 2.0V 至 3.6V,工作频率 72MHz,内置 RTC,支持多种省电模式。
功能详解:具备丰富的外设接口,支持多种通信协议,具有 DMA 控制器,支持浮点运算。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP-81 封装。
FST10060 价格&库存
很抱歉,暂时无法提供与“FST10060”相匹配的价格&库存,您可以联系我们找货
FST10060
    • 1+1032.95520
    • 200+412.16040
    • 480+398.39040
    • 1000+391.58640
