201CMQ045
201CMQ045
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
201CMQ045 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1187, Rev. B 201CMQ SERIES Green Products 201CMQ035/201CMQ040/201CMQ045/201CMQ050 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 201CMQ035/040/045/050, 1 row SS YYWWL, 2 row 201CMQ035/040/045/050 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 201CMQ SERIES Technical Data Data Sheet N1187, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =121°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 3840 A EAS TJ=25℃,IAS=20A,L=0.67mH 135 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 20 A Symbol Condition @ 100A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 25 °C @ 100A, Pulse, TJ = 125 °C @ 200A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - 35 40 45 50 100 200 Max. 201CMQ035 201CMQ040 201CMQ045 201CMQ050 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Max. 0.67 0.81 0.58 0.71 10 90 Units V V mA mA 5200 pF 7.0 nH 10,000 V/μs Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
201CMQ045
物料型号: - 201CMQ035 - 201CMQ040 - 201CMQ045 - 201CMQ050
器件简介: 201CMQ系列是SANGDEST MICROELECTRONICS生产的肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
引脚分配: - 阳极1 = 端子1 - 阳极2 = 端子3 - 公共阴极 = 端子2 - 后缀R表示反向极性 - PRM4(隔离)
参数特性: - 峰值反向电压(VRWM):35V至50V不等,具体取决于型号。 - 最大平均正向电流(IF(AV)):每腿100A,设备总200A。 - 最大单周期非重复浪涌电流(IFSM):3840A。 - 非重复雪崩能量(EAS):135mJ。 - 重复雪崩电流(IAR):20A。 - 最大正向电压降(VF):在100A和200A条件下分别为0.67V至0.81V。 - 最大反向电流(IR):在室温下每腿10mA,125°C时为90mA。 - 最大结电容(CT):5200pF。 - 典型串联电感(Ls):7.0nH。 - 最大电压变化率(dv/dt):10000V/μs。
功能详解: 这些肖特基整流器能在175℃的结温下工作,具有中心抽头模块、高纯度高温环氧封装、低正向电压降、高频率操作能力、增强的鲁棒性和长期可靠性。此外,这些器件是无铅的,所有SMC部件都可以追溯到晶圆批次。
应用信息: 适用于需要高电流和高可靠性的应用,如开关电源、电镀电源、UPS系统等。
封装信息: - 封装树脂:环氧树脂UL:94V-0。 - 封装风格:PRM4隔离。
201CMQ045 价格&库存
很抱歉,暂时无法提供与“201CMQ045”相匹配的价格&库存,您可以联系我们找货
