SANGDEST
MICROELECTRONICS
Technical Data
Data Sheet N1189, Rev. B
203CNQ SERIES
Green Products
203CNQ080/203CNQ100
SCHOTTKY RECTIFIER
Applications:
● High current switching power supply ● Plating power supply ● Free-Wheeling diodes
● Reverse battery protection ● Converters ● UPS System ● Welding
Features:
175 ℃ TJ operation
Center tap module
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
Low forward voltage drop
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm/ Inches
PRM4 (Non-Isolated)
MARKING,MOLDING RESIN
st
nd
Marking for 203CNQ080/100, 1 row SS YYWWL, 2 row 203CNQ080/100
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL:94V-0
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
203CNQ SERIES
Technical Data
Green Products
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Current(peg leg)
Symbol
VRWM
Condition
IF(AV)
50% duty cycle @TC =110°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
EAS
80
100
100
200
Max.
203CNQ080
203CNQ100
per leg
per device
Units
V
A
2520
A
TJ=25℃,IAS=1A,L=30mH
15
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×
VR typical
1
A
Symbol
Condition
@ 100A, Pulse, TJ = 25 °C
@ 200A, Pulse, TJ = 25 °C
@ 100A, Pulse, TJ = 125 °C
@ 200A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg) *
VF1
VF2
Max. Reverse Current (per
leg) *
Max. Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
Insulation Volage
IR1
IR2
CT
LS
dv/dt
VRMS
Max.
0.86
1.03
0.70
0.84
3
40
Units
V
V
mA
mA
2650
Pf
7.0
Nh
10,000
1000
V/μs
V
Specification
-55 to +175
-55 to +175
Units
°C
°C
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“203CNQ080”相匹配的价格&库存,您可以联系我们找货
