224CNQ035
224CNQ035
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
224CNQ035 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1198, Rev. B 224CNQ SERIES Green Products 224CNQ035/224CNQ040/224CNQ045 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 125 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 224CNQ035/040/045, 1 row SS YYWWL, 2 row 224CNQ035/040/045 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 224CNQ SERIES Technical Data Data Sheet N1198, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM Condition - 35 40 45 110 220 Max. 224CNQ035 224CNQ040 224CNQ045 per leg per device Units V IF(AV) 50% duty cycle @TC =81°C, rectangular wave form A IFSM 8.3 ms, half Sine pulse 2880 A EAS TJ=25℃,IAS=20A,L=0.67mH 135 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 20 A Symbol Condition @ 110A, Pulse, TJ = 25 °C @ 220A, Pulse, TJ = 25 °C @ 110A, Pulse, TJ = 125 °C @ 220A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Max. 0.52 0.68 0.50 0.68 10 1200 Units V V mA mA 5200 pF 7.0 nH 10,000 V/μs Specification -55 to +125 -55 to +125 Units °C °C Pulse Width < 300µs, Duty Cycle
224CNQ035
物料型号:224CNQ035/040/045 器件简介:肖特基整流器 引脚分配:2X49(025) - 六角形阳极;3 1/4-20 SLOTTED HEX ANODE - 阳极;COMMON CATHOD BASE - 公共阴极 参数特性: - 最大反向工作电压:35V、40V、45V - 最大平均正向电流:每腿110A,整个器件220A - 最大正向压降:在25°C和125°C时分别为0.52V和0.50V - 最大反向电流:在25°C时为10mA,在125°C时为1200mA - 最大结电容:5200pF - 最大电压变化率:10,000V/us 功能详解: - 高温操作(最高125℃) - 中心抽头模块 - 低正向电压降 - 适用于高频操作 - 有加强环以提高鲁棒性和长期可靠性 - 无铅设备 应用信息:适用于高电流开关电源、电镀电源、自由轮二极管、反极性电池保护、转换器、UPS系统和焊接等应用。
封装信息:PRM4(非隔离型),标记为224CNQ035/040/045,第一行标记为SS YYWWL,第二行为型号。
其中YY代表生产年份,WW代表生产周代码,L代表晶圆批次号。
封装材料为UL94V-0标准的环氧树脂。
224CNQ035 价格&库存
很抱歉,暂时无法提供与“224CNQ035”相匹配的价格&库存,您可以联系我们找货
