225CNQ015
225CNQ015
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
225CNQ015 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1200, Rev. B 225CNQ015 Green Products 225CNQ015 SCHOTTKY RECTIFIER Applications: ● Parallel switching power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● Redundant power subsystems Features: • • • • • • • • • 125℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 225CNQ015, 1 row SS YYWWL, 2 row 225CNQ015 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 225CNQ015 Technical Data Data Sheet N1200, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM IF(AV) Condition 50% duty cycle @TC =74°C, rectangular wave form IFSM 8.3 ms, half Sine pulse EAS 110 220 Max. 15 per leg per device Units V A 2040 A TJ=25℃,IAS=2A,L=4.5mH 9 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 2 A Symbol VF1 Condition @ 110A, Pulse, TJ = 25 °C @ 220A, Pulse, TJ = 25 °C @ 110A, Pulse, TJ = 125 °C @ 220A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = rated VR TJ = 100 °C @VR = rated VR TJ = 100 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.38 0.49 0.32 0.42 40 2000 1780 1080 Units V 7700 pF 7.0 nH 10,000 V/μs Condition - Specification -55 to +125 -55 to +125 Units °C °C Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 IR3 IR4 CT LS dv/dt V mA mA mA mA Pulse Width < 300µs, Duty Cycle
225CNQ015 价格&库存
很抱歉,暂时无法提供与“225CNQ015”相匹配的价格&库存,您可以联系我们找货
