220CMQ025
220CMQ025
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
220CMQ025 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1193, Rev. B 220CMQ025 Green Products 220CMQ025 SCHOTTKY RECTIFIER Applications: ● Parallel switching power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● Redundant power subsystems Features: • • • • • • • • • 150℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 220CMQ025, 1 row SS YYWWL, 2 row 220CMQ025 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 220CMQ025 Technical Data Data Sheet N1193, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Max. Average Forward IF(AV) Condition 50% duty cycle @TC =74°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 2850 A Condition @ 110A, Pulse, TJ = 25 °C @ 110A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.48 0.40 Units V V 10 mA 560 mA 7400 pF 7.0 nH 10,000 V/μs Condition - Specification -55 to +150 -55 to +150 Units °C °C 110 220 Max. 25 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current at DC condition Max. Reverse Current Max. Junction Capacitance Typical Series Inductance (per leg) Max. Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Pulse Width < 300µs, Duty Cycle
220CMQ025
### 物料型号 - 型号:220CMQ025
### 器件简介 - 应用:该器件适用于并联开关电源、自由轮流通路二极管、反向电池保护、转换器、冗余电源子系统等。 - 特点:150℃的工作温度、中心抽头模块、高纯度、耐高温环氧封装以增强机械强度和防潮性能、低正向电压降、高频操作、增强的保护环以提高鲁棒性和长期可靠性、无铅设备、所有SMC部件都可以追溯到晶圆批次。
### 引脚分配 - 阳极1:终端1 - 阳极2:终端3 - 共阴极:终端2 - 后缀R:表示反向极性。
### 参数特性 - 最大反向峰值电压(VRWM):25V - 最大平均正向电流(IF(AV)):每腿110A,设备总共220A - 最大峰值非重复浪涌电流(IFSM):2850A(8.3ms,半正弦脉冲) - 最大正向电压降(VF1):在110A脉冲,25°C时为0.48V(每腿) - 最大反向电流在直流条件下(IR1):在额定VR,25°C时为10mA - 最大反向电流(IR2):在额定VR,125°C时为560mA - 最大结电容(CT):在5V,25°C,1MHz信号频率时为7400pF - 典型串联电感(Ls):从封装体5mm处测量,每腿7.0nH - 最大电压变化率(dv/dt):10000V/us
### 功能详解 - 该器件是一个无铅的Schottky整流器,具有高效率和高可靠性,适用于高功率应用。
### 应用信息 - 适用于需要高效率整流和保护的场合,如电源转换和电池反向保护。
### 封装信息 - 封装类型:PRM4(隔离) - 封装材料:环氧树脂,UL94V-0等级
220CMQ025 价格&库存
很抱歉,暂时无法提供与“220CMQ025”相匹配的价格&库存,您可以联系我们找货
