SANGDEST
MICROELECTRONICS
Technical Data
Data Sheet N1196, Rev. B
220CNQ030
Green Products
220CNQ030 SCHOTTKY RECTIFIER
Applications:
● High current switching power supply ● Free-Wheeling diodes● Reverse battery protection
● Converters ● Welding
Features:
150℃ TJ operation
Center tap module
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
Low forward voltage drop
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm/ Inches
PRM4 (Non-Isolated)
MARKING,MOLDING RESIN
st
nd
Marking for 220CNQ030, 1 row SS YYWWL, 2 row 220CNQ030
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL:94V-0
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
220CNQ030
Technical Data
Green Products
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Current(peg leg)
Symbol
VRWM
IF(AV)
Condition
50% duty cycle @TC =100°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
EAS
110
220
Max.
30
per leg
per device
Units
V
A
2880
A
TJ=25℃,IAS=22A,L=0.41mH
99
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×
VR typical
22
A
Symbol
VF1
Condition
@ 110A, Pulse, TJ = 25 °C
@ 220A, Pulse, TJ = 25 °C
@ 110A, Pulse, TJ = 125 °C
@ 220A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Max.
0.48
0.57
0.40
0.52
Units
V
10
mA
560
mA
7400
pF
7.0
nH
10,000
1000
V/μs
V
Condition
Specification
-55 to +150
-55 to +150
Units
°C
°C
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg) *
VF2
Max. Reverse Current at DC
condition
Max. Junction Capacitance
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
Insulation Voltage
IR1
IR2
CT
LS
dv/dt
VRMS
V
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“220CNQ030”相匹配的价格&库存,您可以联系我们找货
