209CNQ135
209CNQ135
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
209CNQ135 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1240, Rev. B 209CNQ…SERIES Green Products 209CNQ135/209CNQ150 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 °C TJ operation Center tap module Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING, MOLDING RESIN st nd Marking for 209CNQ135/150, 1 row SS YYWWL, 2 row 209CNQ135/150 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 209CNQ…SERIES Technical Data Data Sheet N1240, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Symbol Condition VRWM - 135 Max. 209CNQ135 150 100 200 209CNQ150 peg leg peg device Units V Max. Average Forward Current * IF(AV) 50% duty cycle @TC =110°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (peg leg) IFSM 8.3 ms, half Sine pulse 1440 A Condition @ 100A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 25 °C @ 100A, Pulse, TJ = 125 °C @ 200A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR ,TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 1.03 1.22 0.71 0.82 3 45 Units 3000 pF 7.0 nH 10,000 V/μs Specification -55 to +175 -55 to +175 Units °C °C A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt V V mA mA Pulse Width < 300µs, Duty Cycle
209CNQ135 价格&库存
很抱歉,暂时无法提供与“209CNQ135”相匹配的价格&库存,您可以联系我们找货
