300CNQ040
300CNQ040
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
300CNQ040 数据手册
SANGDEST MICROELECTRONICS 300CNQ… SERIES Technical Data Data Sheet N1210, Rev. C Green Products 300CNQ SERIES SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 150 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches 300CNQ035 300CNQ035R Please Note: Suffix “R” Denotes For Reversed Polarity PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 300CNQ035/R, 1 row SS YYWWL, 2 row 300CNQ035/300CNQ035R Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 300CNQ… SERIES Technical Data Data Sheet N1210, Rev. C Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =104°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 2880 A EAS TJ=25℃,IAS=30A,L=0.67mH 150 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 30 A Symbol Condition @ 150A, Pulse, TJ = 25 °C @ 300A, Pulse, TJ = 25 °C @ 150A, Pulse, TJ = 125 °C @ 300A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - 35 40 45 150 300 Max. 300CNQ035/R 300CNQ040/R 300CNQ045/R per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Max. 0.61 0.77 0.62 0.75 15 750 Units V V mA mA 7750 pF 6.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
300CNQ040 价格&库存
很抱歉,暂时无法提供与“300CNQ040”相匹配的价格&库存,您可以联系我们找货
300CNQ040
  • 198+550.20073198+71.42500
