301CMQ040
301CMQ040
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
301CMQ040 数据手册
301CMQ… SERIES Technical Data Data Sheet N1211, Rev. B Green Products 301CMQ035/301CMQ040/301CMQ045/301CMQ050 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 301CMQ035/040/045/050, 1 row SS YYWWL, 2 row 301CMQ035/040/045/050 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 301CMQ… SERIES Technical Data Data Sheet N1211, Rev. B Green Products Maximum Ratings: Characteristics Symbol Condition - 35 40 45 50 150 300 Max. 301CMQ035 301CMQ040 301CMQ045 301CMQ050 per leg per device Units V Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR Average Forward Current IF(AV) 50% duty cycle @TC =81°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 3840 A EAS TJ=25℃,IAS=40A,L=0.34mH 202 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 30 A Condition @ 150A, Pulse, TJ = 25 °C @ 300A, Pulse, TJ = 25 °C @ 150A, Pulse, TJ = 125 °C @ 300A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.69 0.90 0.59 0.76 10 90 Condition - Specification -55 to +175 -55 to +175 Units °C °C Peak One Cycle Non-Repetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) A Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS Units V V mA mA 5200 pF 7.0 nH 10,000 1000 V/μs V Pulse Width < 300µs, Duty Cycle
301CMQ040
物料型号:301CMQ035/301CMQ040/301CMQ045/301CMQ050
器件简介:这是一系列肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
引脚分配:Anode $1 = Terminal 1; Anode $2 = Terminal 3; Common Cathode = Terminal 2。
后缀R表示反向极性。
参数特性: - 最高重复反向电压(VRRM):35V、40V、45V、50V - 工作峰值反向电压(VRWM):35V、40V、45V、50V - DC阻断电压(VR):35V、40V、45V、50V - 平均正向电流(IF(AV)):每腿150A,设备300A - 峰值非重复浪涌电流(IFSM):3840A - 非重复雪崩能量(EAS):202mJ - 重复雪崩电流(IAR):30A
功能详解: - 175℃ TJ操作 - 中心抽头模块 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 低正向电压降 - 高频操作 - 保护环增强了坚固性和长期可靠性 - 无铅设备 - 所有SMC零件都可以追溯到晶圆批次 - 可以根据要求提供额外测试
应用信息:适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
封装信息:PRM4(隔离)封装,尺寸为81.28mm x 78.74mm x 40.26mm,带有槽口的六角形,底座隔离。
标记为301CMQ035/040/045/050,第一行SS YYWWL,第二行301CMQ035/040/045/050,其中YY是制造年份,WW是制造周代码,L是晶圆批次编号。
封装树脂为环氧树脂UL:94V-0。
301CMQ040 价格&库存
很抱歉,暂时无法提供与“301CMQ040”相匹配的价格&库存,您可以联系我们找货
301CMQ040
  • 198+446.50597198+57.96374
