301CNQ035
301CNQ035
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
301CNQ035 数据手册
301CNQ… SERIES Technical Data Data Sheet N1212, Rev. B Green Products 301CNQ035/301CNQ040/301CNQ045/301CNQ050 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 301CNQ035/040/045/050, 1 row SS YYWWL, 2 row 301CNQ035/040/045/050 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 301CNQ… SERIES Technical Data Data Sheet N1212, Rev. B Green Products Maximum Ratings: Characteristics Symbol Condition - 35 40 45 50 150 300 Max. 301CNQ035 301CNQ040 301CNQ045 301CNQ050 per leg per device 3840 Units V Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR Average Forward Current IF(AV) Peak One Cycle Non-Repetitive Surge Current per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) IFSM 50% duty cycle @TC =81°C, rectangular wave form 8.3 ms, half Sine pulse EAS TJ=25℃,IAS=40A,L=0.34mH 202 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 30 A Max. 0.69 0.90 0.59 0.76 10 135 Units A A Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS Condition @ 150A, Pulse, TJ = 25 °C @ 300A, Pulse, TJ = 25 °C @ 150A, Pulse, TJ = 125 °C @ 300A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - V V mA mA 7800 pF 7.0 nH 10,000 1000 V/μs V Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
301CNQ035
物料型号:301CNQ035/301CNQ040/301CNQ045/301CNQ050 器件简介:肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
引脚分配:中心抽头模块,带有阳极和阴极的引脚。
参数特性:175℃ TJ操作,低正向电压降,高频率操作,增强的鲁棒性和长期可靠性。
功能详解:高纯度、耐高温环氧封装,增强机械强度和防潮性。
应用信息:适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等。
封装信息:PRM4(非隔离型),标记为301CNQ035/040/045/050,采用UL94V-0环氧树脂封装。
301CNQ035 价格&库存
很抱歉,暂时无法提供与“301CNQ035”相匹配的价格&库存,您可以联系我们找货
