301CNQ… SERIES
Technical Data
Data Sheet N1212, Rev. B
Green Products
301CNQ035/301CNQ040/301CNQ045/301CNQ050
SCHOTTKY RECTIFIER
Applications:
● High current switching power supply ● Plating power supply ● Free-Wheeling diodes
● Reverse battery protection ● Converters ● UPS System ● Welding
Features:
175 ℃ TJ operation
Center tap module
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
Low forward voltage drop
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm/ Inches
PRM4 (Non-Isolated)
MARKING,MOLDING RESIN
st
nd
Marking for 301CNQ035/040/045/050, 1 row SS YYWWL, 2 row 301CNQ035/040/045/050
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL:94V-0
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
301CNQ… SERIES
Technical Data
Green Products
Maximum Ratings:
Characteristics
Symbol
Condition
35
40
45
50
150
300
Max.
301CNQ035
301CNQ040
301CNQ045
301CNQ050
per leg
per device
3840
Units
V
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
Average Forward Current
IF(AV)
Peak One Cycle Non-Repetitive
Surge Current per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Repetitive Avalanche Current(peg
leg)
IFSM
50% duty cycle @TC =81°C,
rectangular wave form
8.3 ms, half Sine pulse
EAS
TJ=25℃,IAS=40A,L=0.34mH
202
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×
VR typical
30
A
Max.
0.69
0.90
0.59
0.76
10
135
Units
A
A
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Voltage Rate of Change
Insulation Voltage
IR1
IR2
CT
LS
dv/dt
VRMS
Condition
@ 150A, Pulse, TJ = 25 °C
@ 300A, Pulse, TJ = 25 °C
@ 150A, Pulse, TJ = 125 °C
@ 300A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
V
V
mA
mA
7800
pF
7.0
nH
10,000
1000
V/μs
V
Specification
-55 to +175
-55 to +175
Units
°C
°C
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“301CNQ040”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 198+550.89012198+71.63089
