306CNQ200
306CNQ200
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
306CNQ200 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1217, Rev. B 306CNQ200 Green Products 306CNQ200 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 306CNQ200, 1 row SS YYWWL, 2 row 306CNQ200 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 306CNQ200 Technical Data Data Sheet N1217, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =121°C, rectangular wave form 8.3 ms, half Sine pulse 150 300 Max. 200 per leg per device 3840 Units V A A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS Condition @ 150A, Pulse, TJ = 25 °C @ 300A, Pulse, TJ = 25 °C @ 150A, Pulse, TJ = 125 °C @ 300A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.86 1.03 0.76 0.86 10 90 Units V V mA mA 3500 pF 7.0 nH 10,000 1000 V/μs V Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
306CNQ200
物料型号:306CNQ200 器件简介:该器件是一种肖特基整流器,适用于高电流开关电源、电镀电源、自由轮二极管、反向电池保护、转换器、UPS系统和焊接等领域。
引脚分配:提供中心抽头模块和非隔离型引脚配置。
参数特性:最大反向峰值电压200V,最大平均正向电流150A/腿,最大正向电流300A/设备,正向电压降在125°C时最大为0.86V,最大反向电流在25°C时为10mA,在125°C时为90mA。
功能详解:工作温度范围为-55至175摄氏度,采用高纯度、耐高温的环氧树脂封装,增强了机械强度和防潮性能,并具有低正向电压降、高频率操作能力。
应用信息:适用于需要高电流和高可靠性的电源和保护系统。
封装信息:PRM4(非隔离型),尺寸为81.28mm x 78.74mm x 40.26mm,重量约为79克,采用UL94V-0标准的环氧树脂封装。
306CNQ200 价格&库存
很抱歉,暂时无法提供与“306CNQ200”相匹配的价格&库存,您可以联系我们找货
306CNQ200
  • 198+446.03767198+57.96374
