309CNQ135
309CNQ135
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
309CNQ135 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1219, Rev. B 309CNQ… SERIES Green Products 309CNQ135/309CNQ150 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 309CNQ135/150, 1 row SS YYWWL, 2 row 309CNQ135/150 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 309CNQ… SERIES Technical Data Data Sheet N1219, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =110°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 135 150 150 300 Max. 309CNQ135 309CNQ150 per leg per device 1440 Units V A A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 150A, Pulse, TJ = 25 °C @ 300A, Pulse, TJ = 25 °C @ 150A, Pulse, TJ = 125 °C @ 300A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 1.03 1.22 0.71 0.82 3 45 Units V V mA mA 4000 pF 7.0 nH 10,000 V/μs Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
309CNQ135
物料型号:309CNQ135/309CNQ150 器件简介:肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统、焊接等。
引脚分配:中心抽头模块,2X69(0235)、35.687(1.405) 34.163(1.345) 4.70 (0.185) 4.95(0.195)、63.50(2.500) 60.96 (2.400) 3 1/4-20 SLOTTED HEX ANODE ANODE。
参数特性:最大反向峰值电压为135V/150V,最大平均正向电流为150A/腿,最大正向电压降为1.03V/1.22V,最大反向电流为3mA/45mA,最大结电容为4000pF,最大电压变化率为10,000V/us。
功能详解:175℃ TJ操作,低正向电压降,高频率操作,增强的鲁棒性和长期可靠性,无铅设备,所有SMC部件均可追溯至晶圆批次。
应用信息:高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统、焊接。
封装信息:PRM4(非隔离),标记为309CNQ135/150,第一行SS YYWWL,第二行309CNQ135/150,YY代表制造年份,WW代表制造周代码,L代表晶圆批次号,模塑树脂为环氧树脂UL:94V-0。
309CNQ135 价格&库存
很抱歉,暂时无法提供与“309CNQ135”相匹配的价格&库存,您可以联系我们找货
309CNQ135
  • 198+446.50597198+57.96374
