400CMQ040
400CMQ040
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
400CMQ040 数据手册
SANGDEST MICROELECTRONICS 400CMQ… SERIES Technical Data Data Sheet N1222, Rev. B Green Products 400CMQ035/400CMQ040/400CMQ045 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 150 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 400CMQ035/040/045, 1 row SS YYWWL, 2 row 400CMQ035/040/045 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 400CMQ… SERIES Technical Data Data Sheet N1222, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =104°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 4080 A EAS TJ=25℃,IAS=40A,L=0.22mH 180 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 40 A Symbol Condition @ 200A, Pulse, TJ = 25 °C @ 400A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 125 °C @ 400A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - 35 40 45 200 400 Max. 400CMQ035 400CMQ040 400CMQ045 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS Max. 0.57 0.73 0.52 0.68 20 800 Units V V mA mA 10300 pF 5.0 nH 10,000 1000 V/μs V Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
400CMQ040
物料型号: - 400CMQ035 - 400CMQ040 - 400CMQ045
器件简介: 400CMQ系列是高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等领域应用的肖特基整流器。这些器件具有150℃的工作结温、中心抽头模块、高纯度高温环氧封装、低正向电压降、高频率操作能力、增强的鲁棒性和长期可靠性,并标记为无铅设备。
引脚分配: - 阳极1 = 端子1 - 阳极2 = 端子3 - 公共阴极 = 端子2 - 后缀R表示反向极性 - PRM4(隔离)
参数特性: - 峰值反向电压(VRWM):35V(400CMQ035)、40V(400CMQ040)、45V(400CMQ045) - 最大平均正向电流(IF(AV)):每腿200A,设备总400A - 最大峰值单周期非重复浪涌电流(IFSM):4080A - 非重复雪崩能量(EAS):180mJ - 重复雪崩电流(IAR):40A - 最大正向电压降(VF1、VF2):在不同条件下分别为0.57V、0.73V、0.52V和0.68V - 最大反向电流(IR1、IR2):在不同条件下分别为20mA和800mA - 最大结电容(Cr):10300pF - 典型串联电感(Ls):5.0nH - 最大电压变化率(dv/dt):10000V/us - 绝缘电压(VRMS):1000V
功能详解: 这些肖特基整流器具有低正向电压降和高频率操作的特点,适用于高效率的电源转换。它们还具有高纯度的高温环氧封装,增强了机械强度和防潮性能。此外,器件还具有防护环,提高了鲁棒性和长期可靠性。
应用信息: 适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
封装信息: - 封装树脂:环氧树脂UL:94V-0 - 封装风格:PRM4隔离
400CMQ040 价格&库存
很抱歉,暂时无法提供与“400CMQ040”相匹配的价格&库存,您可以联系我们找货
